Help wiring cable - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-24-2010, 05:09 PM - Thread Starter
tom-p's Avatar
I am switching from just cable to cable/ internet and phone package. Currently the cable enters from the outside into my living room. The cable is split and one run goes to the bedroom and the other stays in the living room as seen below
I need to wire cable through the wall to the back bedroom where the Computer is located. I was planning on splitting where it enters and then spit again to run a line for the computer. as seen below
Should I just do a 3 way split at the point where it enters and run three separate cables? Also a friend suggested a signal booster since It will be a long cable run. Should the booster be placed in front of the 2 or 3 way? Thanks for any help.
tom-p is offline
post #2 of 3 Old 04-24-2010, 07:07 PM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
Of those options, an unbalanced 3-way splitter with the hot leg feeding the cable modem would be better. Should not need an amp.
CIAO!
Ed N.
egnlsn is offline
post #3 of 3 Old 04-25-2010, 08:15 AM - Thread Starter
tom-p's Avatar
Thank you
tom-p is offline
Reply Tweaks and Do-It-Yourself
