"Getting Around" Bravia Sync - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-18-2010, 06:02 PM - Thread Starter
WalyB's Avatar
My father has a Sony DVD player, Receiver and LCD-TV all connected by HDMI cables. The problem is, when I want to use the DVD player to listen to CDs or MP3 discs the TV comes on. If you turn off the TV (on the unit or by remote) the other two components turn off as well.
Anyway to stop that ?
WalyB is offline
post #2 of 4 Old 06-19-2010, 01:06 AM
maggiefan's Avatar
Go into the menu and turn off the Bravia sync feature.
Larry
maggiefan is offline
post #3 of 4 Old 07-28-2011, 12:53 AM - Thread Starter
WalyB's Avatar
um, yeah, that kinda defeats the purpose of having it for the ways it DOES work
WalyB is offline
post #4 of 4 Old 08-02-2011, 01:50 PM
m-heat's Avatar
Then you have to deal with it... Or get a harmony or other learning/macro remote.
Picture without sound is surveillance.
m-heat is offline
Reply Tweaks and Do-It-Yourself
