DIY: How to hide wires and cables - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #31 of 42 Old 11-23-2012, 11:58 AM
vail3100's Avatar
I want to just run the power and my cables straight down the wall from where I am mounting my HDTV. The power is not going along the base board and I don't like the look of raceway comng down the wall. What are the new options since this post started in 2009? Whats out there now?
vail3100 is offline
post #32 of 42 Old 11-23-2012, 07:37 PM
olyteddy's Avatar
Quoted: 536 Post(s)
Liked: 941
Drill holes, fish wires...
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #33 of 42 Old 11-23-2012, 11:52 PM - Thread Starter
caper_1's Avatar
Liked: 26
Power cables cannot be fished (safely or legally). Install another outlet behind TV, or install a power bridge, or use raceway.
HT: Yamaha RX-V565 | 3 X Energy Take FPS, 2 X VS Surround, 2 X Take LCR | DIY Subs: SDX12 APR15 & TRIO12 Dual APR 12's | 47" LCD
Music: Yamaha RX-V863 | 2 X Energy RC-70 | MA RXw12 Sub
Bathroom: 2 X Energy Take LCR
Car: Sony Xplod HU, Xplod 6X9s, Kenwood 4"s, Alpine 12" Type-S, Rockford Amp,...
caper_1 is offline
post #34 of 42 Old 12-07-2012, 10:35 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Your authority for that rather exceptional claim?
arnyk is offline
post #35 of 42 Old 12-07-2012, 10:40 AM
Quoted: 176 Post(s)
Liked: 151
The National Electrical Code® NEC® states:
NEC ARTICLE 400 Flexible Cords and Cables General 400.1 Scope.
This article covers general requirements, applications, and construction specifications for flexible cords and flexible cables.
400.8 Uses Not Permitted (ref. Extension Cord) Flexible cords and cables shall not be used for the following:
(1) As a substitute for the fixed wiring of a structure
(2) Where run through holes in walls, structural ceilings, suspended ceilings, dropped ceilings, or floors
(3) Where run through doorways, windows, or similar openings
(4) Where attached to building surfaces
(5) Where concealed by walls, floors, or ceilings or located above suspended or dropped ceilings
HT - JVC RS520 - Anthem AVM 60 - XPA-7 - XPA-5 - GE Triton 2 - GE Supercenter XXL - GE Invisa 650 x 8 - Xbox One - PS4 Pro - Oppo BDP-203 - Dual Rythmik FV15HP's - Lumagen Radiance Pro
My Media Room
kaotikr1 is offline
post #36 of 42 Old 12-07-2012, 12:24 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Irrelevant because you said what you said and addressed it to all power cables, which includes things like Romex, rigid conduit, and flexible conduit.
If you said that power cables that are placed inside walls have to be regular house wiring inside conduit or where applicable Romex, then you would have conveyed the actual situation.
arnyk is offline
post #37 of 42 Old 12-07-2012, 04:48 PM - Thread Starter
caper_1's Avatar
Liked: 26
well, mr exacto, when I refer to "fishing" wires, it usually doesnt refer to romex.... if you were fishing romex, you would be installing and outlet, which is what I ended my statement with.
caper_1 is offline
post #38 of 42 Old 12-07-2012, 04:50 PM - Thread Starter
caper_1's Avatar
Liked: 26
and "power cables" are not romex. they are power cables, as named by many retail stores. Romex isnt a 'cable' per se, it is wire.
caper_1 is offline
post #39 of 42 Old 12-11-2012, 01:47 PM
Colm's Avatar
Liked: 94
No. Romex is a type of NM cable. An electrical cable is simply several wires in the same sheath.
The restriction in the code is there because of the difference in construction between a flexible cable or cord such as typically used to plug a device into a receptacle, and a cable that is to meant to be permanently installed in the structure. Regardless of what you call it, if it is going in the wall, it has to meet the requirements of your local code, which in the USA is usually some flavor of the NEC, and the power cords that come with CE equipment won't meet those requirements.
Colm is offline
post #40 of 42 Old 12-13-2012, 07:36 AM - Thread Starter
caper_1's Avatar
Liked: 26
exactly. That was my whole point. Some people put the device power cable (to outlet) inside walls, or even extension cords. These require cooling, anc will heat up inside the wall, eventually resulting in insulation failure (brittle, etc), and fire. Then insurance will not cover your losses because of the code violation.
caper_1 is offline
post #41 of 42 Old 01-15-2013, 03:31 AM
SirCodyJeepster's Avatar
Hey all.... I'm lazy and did it the Lazy way...lol....No sawing, fishing wires, or Building involved....lol...Stick it, Paint it you're done...lol...
Flat wire Hdmi.png 1275k .png file
Flat Wire.png 1125k .png file
Name:	Flat wire Hdmi.png
ID:	66318   Click image for larger version
caper_1 likes this.
SirCodyJeepster is offline
post #42 of 42 Old 01-15-2013, 06:51 AM - Thread Starter
caper_1's Avatar
Liked: 26
Very nice !! curious as to how much flatwire you needed, where you got it, and the cost ?
caper_1 is offline
Reply Tweaks and Do-It-Yourself
