Is Toggle bolting a LCD TV and mount OK? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 58 Old 02-21-2011, 12:46 AM - Thread Starter
escheng's Avatar
Well, not really. But, there turned out to be A stud, that actually was pretty close to center! It took a lot of probing and a lot of testing with little nails, but I found it. There is so much dry wall plaster (added an additional 1/2" to the wall thickness) and the texture is uneven enough that my stud finder couldn't find it (or I need a new stud finder).
Anyways, the TV's are mounted and solid in the stud. It looks pretty cool. For the 40", I put a center screw into the stud and used the Toggler Snaptoggle bolts on either side. These Snaptoggles are solid! The 26" underneath only needed screws in the center, so no problem there.
Thanks to everyone for their input!
Giz- I appreciate the concern you had in all your posts. Please believe me that I do not take safety lightly. I have a two year old daughter and another on the way and all I think about is their safety. I don't take shortcuts. I presented these questions because I'm not sure that using these particular types of toggle bolts are necessarily shortcuts. Not when I hear installers are using them and Samsung includes them as an install option in their packaging. They even put out a video showing you how to use these toggle bolts to mount their TV's. The gentleman at the HT store I mentioned wasn't just some employee-- he was the previous owner of the store and has been in the business for at least 20 years. I make sure I talk to a lot of the right people, including looking at forums like this one. I like to do a lot of home projects on my own, but I make sure I research every detail as much as I can.
Again, thanks for your comments and concerns!
escheng is offline
post #32 of 58 Old 02-21-2011, 06:55 AM
video321's Avatar
Quoted: 21 Post(s)
I'm glad you got it sorted out and wasn't able to figure out why you couldn't hit at least 1 stud for your mount. I have 24" OC studs in my house and it didn't work out too well for one of my 32" mounts. I was able to center it to the wall with a single stud running close to the center of the mount so I put 2 lags in there. Then I added a heavy duty wall anchor to each corner (4). Now, I would never had used anchors by themselves, but along with the lags running through the center this thing isn't going anywhere!
video321 is offline
post #33 of 58 Old 02-21-2011, 03:15 PM
Alex2507's Avatar
Originally Posted by BllDo View Post
The Sanus mount you mentioned is 30" wide. Even at 24" OC you should still be able to hit two studs.
Not true. If you have 3 studs @ 24" OC the space between the outer 2 is 46.5" and there is only one stud in the middle. With studs 16" @ OC you end up with 1 stud in 30.5".
I like to use a piece of 3/4" edge banded plywood painted black the same size (or a little bigger) as the back of the mount and secure that to the stud/s. Then I secure the mount to the plywood and the stud/s. It's an extra step but when we bought our 50" Panny it was close to 2 grand and I felt better with the over kill.
Alex2507 is offline
post #34 of 58 Old 02-21-2011, 10:09 PM - Thread Starter
escheng's Avatar
This section of wall was originally two open cubbies framed to hold the old larger TV's. I had a contractor close up the cubby on the exercise room side and remodel the bathroom side to make a vanity area. The wall is 47" wide, and I assumed (when I couldn't locate any studs with my stud finder) that he put up a board of sheetrock without studs in the middle. At that time, I didn't have plans for the wall. Thankfully, he did put up a stud and, thankfully, I found it! The TV's cover up most of the small nail holes I put all over the wall.
escheng is offline
post #35 of 58 Old 02-22-2011, 03:57 PM
alk3997's Avatar
Liked: 92
Originally Posted by jneutron View Post
I guess it's time to invoke the dreaded "Maxwell Cremona" diagram, eh??
If one could tighten all the screws with no load on the wall, the ideal condition of equal vertical force on the anchors would be realized. In reality, it would be close..
All the anchors would be supporting the dead weight of the unit. This appears as a shear force on each anchor. Within the structure of the drywall, there will indeed be compressive forces on the lower 180 degrees of the hole. Moly's will spread this to more of the drywall, but in essentially point contact locations. If the moly is overtightened, it will puncture the paper and render the rock susceptible to long term failure, the core of drywall is not very good at high stress. (this is why you don't want drywall screws to pop the paper as it's being tightened.)
Because the center of gravity of the unit is away from the wall, the upper anchors will be required to withstand a tensile force normal to the wall (translation, it's pulling away from the wall). This will add to the compression on the backside of the rock. If the anchors have bitten through the paper, again, not good long term.
NONE of this will occur with a 2 inch #10 wood screw in a stud.
I stand by gizmologist's recommendations.
Cheers, John
One other item that might be of use - no TV I've seen has the same amount of weight on both sides. In other words the mass distribution is not uniform throughout the TV and the TV is not a point source (obviously).
So what you would get in a failure is a rotational force as well as the top bolts pull away with one side pulling away faster than the other. Depending upon how strong the bottom wall is, this could also lead to a compressive force on one of the bottom bolts while the TV rotates away.
I'd want to be really sure of the wall strength before trying this and then I still wouldn't feel comfortable particularly with vibrations in the room.
Edit - And glad you found the wall stud!
alk3997 is offline
post #36 of 58 Old 03-01-2011, 06:55 AM
jneutron's Avatar
""I see you're no stranger to pain"" (statics and dynamics, Beer and Johnson, 1972)
.....I've been divorced.. (ooooh!!!)
Twice.. (OOOOOOOOHHH!!).
Nice comments...
Cheers, John
Some discuss because they can. Others attack because they cannot. (unknown attribution)
A good man knows his own limitations...(Dirty Harry)
Lead, follow....or get out of the way..
jneutron is offline
post #37 of 58 Old 03-01-2011, 08:09 PM
bjex500's Avatar
I'll bet I have that book in my office.
bjex500 is offline
post #38 of 58 Old 03-02-2011, 02:59 PM
jneutron's Avatar
Geek!!!
jneutron is offline
post #39 of 58 Old 06-16-2011, 04:00 PM
gatordude2000's Avatar
How is this setup working out for you? I am in a similar boat, with a stud located exactly on the center of where I want to mount the TV. I am thinking about using 2 lag bolts to attach the mount to the stud at the dead center. I would then use 4 togglers to attach to the dry wall at the 4 corners. This is for a 55" TV that weighs 48 lbs. The mount (LG LSW400BG) is not articulating but it does come away from the wall by up to 8" to provide tip-tilt capability. LG advertises this mount as ok for dry wall, but then do not explicitly state this in the installation manual and that is what concerns me.
gatordude2000 is offline
post #40 of 58 Old 06-16-2011, 07:34 PM
MrBobb's Avatar
Quoted: 164 Post(s)
Liked: 63
Oh no... not that 4 months-old thread we all already had our shots at it.
Am going to change my answer, after having re-mod my kitchen and seeing huge cabinets hung by just a few thin bolts and they've up there for years!
If you are going to mount it on the center stud and toggle-bolt on the sides just to steady it, OK do it, but I'd add a third bolt toward the top bolt on the stud because it will make me feel better. Good luck!
MrBobb is offline
post #41 of 58 Old 06-21-2011, 08:22 PM
cshepard's Avatar
Quoted: 21 Post(s)
Liked: 38
27 pounds? 4 SnapToggles? No problem. Yes I'm a pro. No, not a trunk slammer. I wouldn't be able to sleep at night if I EVER hung a TV where there was ANY doubt MY installation would fail. I'd hang 40" LEDs all day long with 4 SnapToggles.
Having said that...First, I'm not going to be responsible for YOUR install or your TV. Second, I would probably be able to find a way to use at least one stud (drill new holes in the mount) before I brought out the Togglers.
cshepard is offline
post #42 of 58 Old 05-30-2014, 08:10 PM
Knocks's Avatar
This is the best thread I've found on the subject, so I'm reviving it. I'm hanging a 60-inch, 45 lbs Samsung TV (UN60F8000) on a drywall using a Samsung-brand mini wall mount WMN450M. The studs are, as expected, in the wrong place and would shift the ideal TV position by 8 inches to the left, so we're looking for other solutions.
The drywall in this apartment is, interestingly, 1-inch thick, as opposed to the typical half-inch--that's twice as much support for the toggle bolts than the usual drywall, if I went that route. Does that make toggle bolts a more acceptable solution in this scenario? Again, the TV is 45 lbs.
Knocks is offline
post #43 of 58 Old 06-02-2014, 08:46 AM
AV_Integrated's Avatar
Quoted: 971 Post(s)
Liked: 718
Does it make it safer? Yes! Is it as safe as using studs? Not at all!
I'm sure you are fine with hanging your cheap TV on something that is not 100% structurally sound, but if you aren't made of money, and replacing the TV isn't your first choice, then get a different mount.
Universal mounts with holes every inch are the only appropriate solution if you aren't able to hit studs or manipulate your wall in other ways.
This mount, for example, fixes your issue, is under $20, and is only .4" from the wall when mounted:
http://www.monoprice.com/Product?c_id=109&cp_id=10917&cs_id=1091701&p_id=10485&seq=1&format=2
Monoprice has many other choices as well.
If you do decide to go strictly with the drywall, the rule is still the same: Use Snaptoggle Togglers by Hilti. They will give the most secure mount in drywall that I've seen.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #44 of 58 Old 06-02-2014, 09:39 AM
NickTheGreat's Avatar
Quoted: 381 Post(s)
Liked: 255
I wouldn't use just toggle bolts. For some of them, maybe, but not solely.
In our room where we had a similar situation, I used at articulating mount to get the TV where I wanted it, but mounted on studs. I wanted it out from the wall anyway, so this may not work for you.
NickTheGreat is offline
post #45 of 58 Old 06-02-2014, 11:57 AM
wkearney99's Avatar
Quoted: 321 Post(s)
Liked: 128
Quite possibly not. The real question is why is there so much drywall up? Because someone half-assed it and just laid another 1/2" layer on top of something in wrecked condition? As in, with cracks, holes, moisture damage or other such issues? Many of which might render the wall WORSE for hanging anything without going into a stud.
Conversely if it's a wall shared with another unit (on the other side) then perhaps they layered and glued it for soundproofing purposes. Hanging on that would present other issues. As in, the noise from the TV would end up radiating through the mounts, negating the point of the layers of drywall.
wkearney99 is offline
post #46 of 58 Old 06-02-2014, 01:00 PM
Knocks's Avatar
The other side is a bedroom. It's an old apartment building, so I don't think their choice of drywall thickness had anything to do with soundproofing or patching things up. Looks like that's just how things were done when it was built. I also spoke with a friend who said if the building is old, it might be plaster and not drywall, but I wouldn't know how to check that.
That mount would not work for this TV. I have already bought four (!) different mounts and decided to go with the Samsung one for several reasons:
1) It's made by Samsung, presumably exactly for this TV
2) the UN60F8000 has a weird thickness issue where the Evolution Kit at the bottom protrudes .8 inches, so mounts under .5 inches would not allow the TV to line up against the wall. At the same time, it's still one of the thinnest 60-inch TV around, and I wanted to take advantage of that and still have it sit as close to the wall as possible
3) It has a kickstand, which allows you to get in behind the TV and plug in new devices as you buy them. That was ultimately the deciding factor.
Knocks is offline
post #47 of 58 Old 06-06-2014, 07:11 AM
SAM64's Avatar
Liked: 78
Since no one makes 1" drywall, it's probably drywall over plaster....you can tell by looking at it. Plaster isn't very strong either.
SAM64 is offline
post #48 of 58 Old 06-06-2014, 07:20 AM
wkearney99's Avatar
Quoted: 321 Post(s)
Liked: 128
It's not an uncommon shortcut for people to lay new drywall over plaster that's in bad shape. Once upon a time plaster was installed by glopping it onto wooden slats. The technique is known as 'plaster and lath'. It's considerably messier to remove and dispose of than drywall. Thus a lot of times people will just leave it up and skin over it because they don't want to suffer the hassle of removing and disposing of it. It's a slipshod way to do things, but such is life.
Where it'll matter for you is presence of plaster & lath under the drywall would make it pretty difficult to truly find the vertical studs, as you'll need those to properly anchor the mount. That and if the drywall on the surface was only screwed into the plaster (and that's in bad shape) then it might have even LESS support than just drywall alone. It's one thing to have new drywall screwed directly into studs. That's got a somewhat reasonable ability to handle some amount of weight on toggles. But if it's just barely screwed into old, cracking plaster? It'd be even less likely to hold anything more than a picture.
I would never, ever use toggles for anything beyond pictures. For a fixed mount that never moved, and a small TV.... maybe. But not EVER for a mount that has a movable arm. The shear forces would be just too much for toggles in drywall.
post #49 of 58 Old 06-07-2014, 09:41 PM
Quoted: 971 Post(s)
Liked: 718
...That mount would not work for this TV. I have already bought four (!) different mounts and decided to go with the Samsung one for several reasons:
It's up to you, but I would put in .3" of washers behind the mount so the mount works perfectly, and hit the studs.
Your TV of course. But, on my side I've hung about 150 flat panel displays, and have used this mount and others with all types of TVs. A few spacers definitely do the trick and get the TV really close to the wall.
post #50 of 58 Old 08-02-2014, 03:51 AM
Liked: 0
Hey everyone, thank you all for your input. I have an old Sharp 65 inch LCD flat screen (just over 200lbs) that I have always mounted with plywood attaching the bracket to the plywood, since the Sharp mount won't fit on 2 studs. 😔. I just moved back to the US from Okinawa, Japan and am trying to get settled in my new home. I wen to the local Lowes today (Anchorage, AL) and asked for a piece of plywood to mount my tv. The guy that was helping me said, "why don't you just use these Toggler bolts and you can mount it directly to the drywall". I told him, you can't hang a 200+ lb tv to dry wall. He assured me that each bolt could hold 265lbs and with 6-8 bolts it would be a piece of cake. Well, he seemed so knowledgeable that I finally bought the bolts. Then I came home to research and found this forum. You all have been debating this for quite some time and have used an incredible amount of actual physics and science to back your opinions. I thank you all for all the feedback. I have decided to mount our 47" Polaroid tv (yeah, they made one 😜) using only the toggler bolts since it is not too heave and it is new Sheetrock and it might be a blessing if it fell and smashed. ☺️ However, I will be going back to get my plywood to mount my 200+lb tv and my 70" sharp that's about 100lbs. To me, it's just not worth the risk of either of those TV mounts failing and hurting any of my kids, or of losing the tv's. Thank you again everyone!!!😄
Erindobbins is offline
post #51 of 58 Old 08-02-2014, 07:37 AM
wkearney99's Avatar
Quoted: 321 Post(s)
Liked: 128
I've not seen it broken down anywhere in particular, but you have to consider how weight is spread across an area, not just what an individual fastener might be rated to handle. The material needs to be able to spread the load. That and handle the stresses of being pulled outward, in addition to just weight pushing down. Putting too many of them too close to each other will exceed the capacity of the material to handle it. How many and how close is certainly an interesting question. I'd venture the folks selling the fasteners have one set of arguments, while the makers of the drywall have others. Given the weight involved and the expense of the gear I'd rather have a bit of overkill.
In the end, you hit on the main point... safety. Both for the people near it and the device itself. You've done the plywood method in the past and had good results, so stick with it.
post #52 of 58 Old 08-02-2014, 01:11 PM
Liked: 0
👍 "If it ain't broke, don't fix it". ☺️
Thank you all again. 😄
post #53 of 58 Old 10-05-2014, 04:10 AM
Liked: 0
Only mollybolts
I am sorry to re-resurrect the thread ones more, but wanted to get your opinions on this.
I am living in a two storey building, and the secondfloors all walls are drywall with no studs. The lazy guy who build the second floor used splashes of concrete to glue drywall to bricks. As they had used a lot of spots it's quite secure.
In the past i did hang kitchen cabinets to the drywall but as home was empty i had the chane to secure it with combination of glue, several mollybolts, woods buried in wall, two very large through the wall bolts that travels to the other side of the wall (and One side of the cabinets are bolted to standart brick wall) . I am checking its status ragularly (3 years) it did not gave a single mm now.
I also bolted a 28 inch LCD TV on a moving hand (that moves out of the wall for 50 cm) with 3 medium sized molly bolts. Its been two years and even i press with a lot of force when the hand is fully extended it does feel extremely secure.
Now i have to hang a Samsung 55hu7500, (no extending arms) it's only 17.8 kg . Drywall is either 5/8 inch or 3/4 inch and there is only 1 - 1.5 cm between bricks and drywall making it hard to use anything other then molly bolts.
Honestly i don't realy mind if tv set falls down and breaks, if and if no one gets hurt. There is no way tv will fall to floor as there is a custom Solid wood hifi rack below it (15-20 cm max) and after falling on it , it may collapse to floor (or got stuck on top of hifi rack)
I can use 4-6 mylar bolts to secure the wall mount (more if needded) so considering that each is 200 lbs + rated for tension and assuming only 3 of'em will share the load , it gives 660 lbs for a 40 lbs TV. There is almost 15X security factor.
But i'd like to hear from you if it is still not allright?
(Tearing down the whole wall and installing studs is impossible in this stage)
Mertol
Mertol is offline
post #54 of 58 Old 10-05-2014, 07:55 AM
wkearney99's Avatar
Quoted: 321 Post(s)
Liked: 128
Please consider using a web browser like Chrome or something that supports spell checking. Especially with it set for the language of the website you're using. They'll show a red underline beneath any suspected spelling errors. It's tough to slog through posts when they're riven with spelling mistakes.
Bolts are not typically Mylar, as that's typically a clear plastic sheeting material, similar to cellophane. More typically they're some kind of nylon. I would not use anything other than metal screws or bolts. The expansion fastener, however, might well be a plastic-type of material. I'd prefer metal though, as they're probably less likely to fail over time.
The trouble with expansion anchors and drywall close to the brick is there's not usually enough room back there for them to expand properly. That and the length of the bolt doesn't have enough depth unless a hole is pre-drilled into the masonry to accommodate it.
You'd likely be better served using a technique common when stud spacing doesn't match desired mounting holes. And that's to affix a sheet of 3/4" finish-grade plywood to the wall first, and then anchor into that. The idea is the plywood can be anchored over a larger area than most mounts. Especially if some construction adhesive is applied between the plywood and the drywall. But not just glue alone, physical fasteners (screws) driven into the material behind will carry most of the load. For your setup that'd likely be masonry screws, aka Tapcon screws. That or other kinds of expanding masonry fasteners. You'd drill holes for them into the bricks and then fasten through the wood & drywall into them.
post #55 of 58 Old 10-05-2014, 10:31 AM
Liked: 0
i was posting from ipad, Safari , sorry for all spelling mistakes.
i mean molly bolts not mylar bolts. The molly bolts i have are all metal ( 6x52 stabilit )
i bought the Sonorus 240 wall mount, which is 80 cm wide and 15 cm tall (arms that attach lcd is 50 cm). I am now planning to use 12 molly bolts , each rated at 220 pounds of tension. Center of gravity of the TV will be 5 cm away from the wall, given the fact arms extend 50 cm vertical plane and mount base extend 80 cm on horizantal plane.
Do you still think that i need to cut a 50x50 hole on dry wall and try to mount a plywood to the bricks?
The bricks that are used in here are a little different ( my post count is not 5 i cant post a link)
What usuallwy hols the anchor is the concrete on the surface of the brick not the brick as you see it's mostly empty inside with thin walls.
While i can still attach plywood to brick in someway i am not positeve that they will hold any better.
Mertol is offline
post #56 of 58 Old 10-05-2014, 10:37 AM
Liked: 0
Here is how my bricks look in person
Mertol is offline
post #57 of 58 Old 10-05-2014, 04:09 PM
wkearney99's Avatar
Quoted: 321 Post(s)
Liked: 128
I take it those bricks are hollow inside? The picture you posted is showing one laid on it's side? Or are they laid that way in the wall, with the open cavities facing out (not up)? If they're hollow vertically then things could get more complicated.
The idea is the combination of glue between the plywood and the drywall, along with a few fasteners through both the plywood AND the drywall to the masonry behind. This gains the benefit of spreading shear forces both to the screws into the masonry AND however the drywall is attached. Not just one or the other alone. When folks have better framing it's typical to just use screws and no adhesive. I wouldn't suggest removing the drywall, it's already there and is already attached to the wall. Removing it wouldn't do much to help other than give you direct access to the bricks. Which you don't really need to access directly.
post #58 of 58 Old 10-05-2014, 10:50 PM
Liked: 0
They are placed in a way that open cavities are facing up.
Mertol is offline
Reply Tweaks and Do-It-Yourself
