Remote power sockets - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-12-2011, 04:45 AM - Thread Starter
JonasHansen's Avatar
Quoted: 148 Post(s)
Liked: 48
I am building a home theater and all equipment is located behind an AT screen. I would like to be able to turn on/off all amps by remote. I have found some plugs you put into the wall socket and then you're able to turn them on or off via a remote. I am going to drive 5 Behringer EP4000 in the system, which is a lot of current!
The specs of the remote things:
Mini remote control socket set with 1 hand transmitter and 3 Schuko plugs. The radiosignals from the transmitter are received even through walls and furniture. 25 m Range (without obstacles) 5 Channels selectable by turn switch Transmission safety by coding Socket with child protection 5 Units (-groups) every single socket is adjustable by remote control Compact switching sockets Ambient temperature range -40°C - +60°C Remote control with indication LED Battery 12 V 23 AE (included) Frequency 434 Mhz Switching of any encumbrances (relays) Any number of devices can be combined Switching power per socket 110-250 V~, Max.5 A, 1000 W Dimension socket (receiver): 56.2 x 106.7 x 77 mm Dimension controller: 37.2 x 116 x 18.8 mm
I am very concerned about the Max 5A / 1000W... What is the consequence of using these plugs?
Home Theater: JBL M2 & SUB18 powered by Crown and BSS.
JonasHansen is offline
post #2 of 5 Old 03-12-2011, 06:03 AM
video321's Avatar
Quoted: 21 Post(s)
You could use a simple power strip to get a full 15A from the wall. Use a relay triggered by your receiver's controlled outlet, if you have that option.
video321 is offline
post #3 of 5 Old 03-12-2011, 11:01 AM
Colm's Avatar
Liked: 94
Do you really need a remote? All my gear is turner off by simply throwing a switch that is in series with all the sockets. The switch doesn't even need to be near the equipment.
If you are going to use the equipment you mentioned, the load has to be within the specified limits.
Colm is offline
post #4 of 5 Old 03-12-2011, 11:19 AM
Gizmologist's Avatar
Liked: 31
You said you are using 5 EP4000 amps. EACH amp requires a 15A 120V supply. That means a separate 20A breaker for each amp! The remote switch you mentioned is in no way capable of handling one let alone 5 amps.
What power have you supplied to the amp rack area?
An amp array of that magnitude should have a sequential power up/down supply as well as audio muting during startup/shutdown.
This is definitely NOT a plug and play setup.
Gizmologist is offline
post #5 of 5 Old 03-13-2011, 03:46 PM
Wayne A. Pflughaupt's Avatar
Quoted: 111 Post(s)
Liked: 78
It'll take some cash, but here ya go: Atlas Sound Power Sequencing System
Never, never, never plug high powered amplifiers into a cheap power strip!!!
Wayne A. Pflughaupt
Equipment List
"A nice mid-fi system," according to an audiophile acquaintance.
Reviews and Tech Articles
Wayne A. Pflughaupt is offline
Reply Tweaks and Do-It-Yourself
