Belkin AP30800-10 just shuts itself off? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #31 of 48 Old 01-14-2015, 10:47 AM
shervinf's Avatar
Is there an easy way to replace the batteries, or do I need to take the whole unit out of the cabinet and take the cover off? (A belkin unit that I have, just required me to take the front cover off).
Thanks for any hints
-S
shervinf is offline
post #32 of 48 Old 01-14-2015, 01:36 PM
usarmycwo's Avatar
nothing to it
"Is there an easy way to replace the batteries, or do I need to take the whole unit out of the cabinet and take the cover off? (A belkin unit that I have, just required me to take the front cover off)."
It's easy, but it does require taking the cover off. After that's done, nothing to it.
Looking back over the posts, I see I replaced the batteries over two years ago. How time flies, seems like just yesterday.
usarmycwo is offline
post #33 of 48 Old 05-28-2015, 10:42 AM
Stogie1020's Avatar
I need to replace the batteries in my unit (charge is never higher than one green bar and I have had the unit and original batteries for for at least 6 years), but can't seem to find any instructions for how to go about this.
Do I remove the front face plate by removing the screws on the sides of the unit or are those only for the rack mount ears? I can't see the back of the unit in it's cabinet so there may be some really obvious panel back there to remove, I just can't see it right now.
What is the process to remove the old batteries and install new ones?
-Thanks
Stogie1020 is offline
post #34 of 48 Old 05-28-2015, 11:00 AM - Thread Starter
Riot Nrrrd's Avatar
Quoted: 14 Post(s)
Do I remove the front face plate by removing the screws on the sides of the unit or are those only for the rack mount ears? I can't see the back of the unit in it's cabinet, so there may be some really obvious panel back there to remove, I just can't see it right now.
I suggest you re-read the entire thread.
You don't need to remove the side screws, just take the whole unit out of your cabinet and undo the one(s) covering the battery area. The 2 batteries are held together by a cable, it should be pretty obvious what's going on once you get those two suckers out of there.
Just to update the thread as the OP, my Arizona Battery replacements from 2011 are still going strong, 4 years later!
Riot Nrrrd is offline
post #35 of 48 Old 05-28-2015, 11:43 AM
Stogie1020's Avatar
Thank you sir, I did read the thread but was not able to discern on which panel the access for the battery was located. I will assume it's on the rear panel.
Thanks, and good to know the AZBatteries are still running. They are local for me so maybe I will see if they do will-call pickup.
post #36 of 48 Old 02-02-2016, 01:42 PM
brycov's Avatar
It is not necessary toremove any of the external small screws on the outside of the case to accessthe battery compartment. Just pulloutward on the front face bezel and it will pop off. Then remove two screws on the right front of the unit and removethe two batteries. Replace the twofailed batteries with two good batteries exactly as the old batteries werewired.
I bought my AP30800-10 unitin May, 2006 and replaced the original Ritar batteries in June, 2009 (lasted 3years) with CSB GP1272F2 12V 7.2 Ah batteries. The CSB batteries just failed in January, 2016 after 6 1/2 years and Ireplaced them again with new CSB batteries (from batteriesasap.com). I'm good to go again for another 6 to 7years.
brycov is offline
post #37 of 48 Old 02-02-2016, 02:11 PM
Stogie1020's Avatar
Wow, thanks for the reply!
In truth, I looked at the device a few days later and the battery indicator seemed to be just where it was supposed to be again... I have had this unit (bought at a Fry's Electronics) since ?2006 or 2007? and other than the hiccup last year where the battery was reading wrong, it has been a champ!
Thanks again for the info, if I ever need it, now I know.
post #38 of 48 Old 08-02-2016, 07:54 PM
jsohng's Avatar
I replaced the batteries, but every since, there is a low hum that is constant. Also more troublesome than that, is that the system occasionally just shuts off and the only way it works is if i unplug it and then plug it into a different socket. The good news is the outlet has 2 sockets and I just alternate, but its quite annoying if it shuts off while i am away and miss recordings. This thing is way old, but has been working like a champ for a while. It'd be a shame to have to toss it.
The main issue for me to follow the steps above is that the power button is broken and doesnt work. There is no springiness to the button, its just flat and cant be pressed. Any suggestions?
jsohng is offline
post #39 of 48 Old 08-29-2016, 07:55 AM
usarmycwo's Avatar
My Belkin PureAV 30800 died, would not power on. Seeing no physical damage inside, I thought it worth taking a chance on a pair of new batteries. No change.
Which led me to wonder if I'd connected them right. Foolishly, I'd taken no photos or made any diagrams before taking the old batteries out. It was a week or two later when the new batteries came in, leaving me unsure of their connections.
I've connected the batteries in parallel (at least I hope I have). What would really help is if someone could say, "The short white wire goes between the (?) terminal on one battery and the (?) terminal on the other...and the long black wire from the system board goes to the (?) terminal on the battery." Or words to that effect.
There's nothing in the user's guide. Belkin's Customer Support is unable or unwilling to help.
Hope you can.
Many thanks.
-- Steve
Name:	30800 complete, open.JPG
ID:	1629553   Click image for larger version
Name:	30800 transformer.JPG
post #40 of 48 Old 08-29-2016, 05:47 PM
usarmycwo's Avatar
Hope you can.
Many thanks.
-- Steve
Let me ask it another way?
Is the short white wire connected between the two negative terminals of the batteries?
Or does it go between the two positive terminals?
Or between a negative and a positive terminal?
That's really all I need to know.
(I'm convinced it's between the two negative terminals, but that's not making the unit come to life. And afraid if I try another way, I'll see sparks and ruin a piece of equipment that might still be fixable.)
post #41 of 48 Old 09-27-2016, 06:59 AM
usarmycwo's Avatar
Batteries connected in series, not parallel
In case anyone cares, the answer is that the short white wire goes between a positive terminal on one battery and a negative terminal on the other.
That surprised me, as it means the batteries are connected in series, not parallel. I'd expected in parallel in order to provide more current, but connecting in parallel simply didn't let the unit turn on, while connecting the batteries in series did.
By the way, yes, new batteries fixed the problem of not turning on.
nathan_h likes this.
Last edited by usarmycwo; 09-27-2016 at 07:01 AM. Reason: I needlessly pasted some of the original post.
post #42 of 48 Old 01-21-2017, 11:23 PM
nathan_h's Avatar
Quoted: 1631 Post(s)
Liked: 1083
Thanks for posting this. I am just about the walk down this path.
usarmycwo likes this.
My current setup.
My favorite movie review podcast, the Next Picture Show.
Don't suffer through Gamma D on your JVC. Optimize HDR Tone Mapping using Arve's tool & Masciola's test patterns instead (hints.)
nathan_h is offline
post #43 of 48 Old 01-22-2017, 07:53 AM
usarmycwo's Avatar
Nathan, am glad it helped.
I'm now on my second set of replacement batteries. Maybe third set, but my memory isn't reliable, and I can remember only two times opening the case.
Which is to say the unit is bulletproof and could last decades with periodic battery replacements.
One thing that might not be obvious is that the unit doesn't have to come out in order to replace the batteries. Instead, just pop off the front panel, giving access to pull the batteries out. Huge time saver that I didn't discover until this last battery swap.
-- Steve
post #44 of 48 Old 02-18-2017, 05:56 AM - Thread Starter
Riot Nrrrd's Avatar
Quoted: 14 Post(s)
I'm (still) the OP, almost 6 years later, my 2nd set of batteries is finally biting the dust! Time to see if Arizona Batteries is still in business ...
Of course, they *would* have to go right at the start of DirecTV's Presidents Day free preview weekend of ALL their Premium movie channels ...
post #45 of 48 Old 02-18-2017, 06:23 AM - Thread Starter
Riot Nrrrd's Avatar
Quoted: 14 Post(s)
P.S. In case anyone's still reading, have any of you given up on the Belkin (due to lack of support or anything else) and investigated any more recent models like the APC J35B? Gotta be better support for an APC product I would think
post #46 of 48 Old 02-18-2017, 03:22 PM
nathan_h's Avatar
Liked: 1083
Arizona batteries is still going strong. Just got a battery replacement for this unit, last month. They sold me a higher capacity battery that at first I thought didn't fit. Their customer support explained how to remove the foam "padding" inside the unit, so the larger battery would fit. It fit like a glove and now my run time is nearly doubled.
Riot Nrrrd and Signal64 like this.
My current setup.
nathan_h is offline
post #47 of 48 Old 05-31-2017, 11:18 PM
Signal64's Avatar
Nice!
Was it their "Belkin BN1250 Replacement Batteries - 12V 9Ah set of 2" or another model?
Signal64 is offline
post #48 of 48 Old 06-01-2017, 02:01 AM - Thread Starter
Riot Nrrrd's Avatar
Quoted: 14 Post(s)
Originally Posted by Signal64 View Post
Nice!
No it is their "APC AP30800-10 PureAV Replacement Battery - 12V 8Ah set of 2" model, AZ Battery product code (searchable) is APCGBAX727. Working like a champ yet again!
RobScreene likes this.
Reply Tweaks and Do-It-Yourself
