Do RCA cables interfere with XLR? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-31-2011, 01:09 PM - Thread Starter
evac311's Avatar
I need to connect my CPU and AVR to my crossover, but the x-over only has 1 set of inputs. I have XLR inputs/outputs on the x-over and the CPU, but not the AVR.
Would I introduce interference or ground loop noise if I ran XLR from CPU to X-over, with a y adapter to splice in RCA audio coming from my AVR? Or would the XLR's be unaffected by the presence of the RCA's?
evac311 is offline
post #2 of 7 Old 03-31-2011, 02:07 PM
Gizmologist's Avatar
Liked: 31
If you wire an RCA connector to an XLR, pins 1(gnd) & 2 (-) of the XLR are tied to ground on the RCA. Pin3 (+) of the XLR goes to the center pin of the RCA. As soon as you connect the "-" pin to the ground, you have unbalanced the RCA and you MAY have a ground loop situation.
To stay balanced and maintain the correct impedance match, XLR and RCA cannot be passively integrated.
Gizmologist is offline
post #3 of 7 Old 04-01-2011, 01:03 PM - Thread Starter
evac311's Avatar
Thanks a lot, gizmologist...that was just the answer I was looking for and I kinda suspected that was the case. Any suggestions for a solution to my problem? Does anyone make an affordable switch for rca/xlr connections? Or am I better off just running rca all the way? It's gonna be a 50 ft run from the cpu to the x-over and I'm worried about signal loss over that length.
evac311 is offline
post #4 of 7 Old 04-01-2011, 03:02 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
Get something like THIS and run your audio as balanced (XLR) as far as you can.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #5 of 7 Old 04-01-2011, 06:16 PM
Speedskater's Avatar
Quoted: 20 Post(s)
In any case, you would never want to connect two different signal sources to one input. Even when you wye a left and right output into a mono input you have to use a small circuit.
Kevin
Speedskater is offline
post #6 of 7 Old 04-01-2011, 06:47 PM - Thread Starter
evac311's Avatar
Thanks olyteddy. That looks like the remedy. You have any personal experience with that product?
evac311 is offline
post #7 of 7 Old 04-03-2011, 01:37 PM
Liked: 31
The Switchcraft transfomer shown has been around a long time. Switchcraft makes a whole series of barrel-style audio problem solvers.
To use that, you still need to make an RCA to XLR adapter cable using the pinouts I posted earlier.
The transformer specs are usually OK for most commercial audio functions but they roll off severely at lower frequencies so using them for a sub feed may be less than stellar if you are looking for uber LF gut-thumper sound.
Reply Tweaks and Do-It-Yourself
