Best place to buy optical cable? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 04-09-2011, 12:40 PM - Thread Starter
ducktailjiver's Avatar
hey all, Ive decided to run some optical cable from my PC to my stereo. wheres a good place to buy 50 foot or so at a decent price?
ducktailjiver is offline
post #2 of 9 Old 04-09-2011, 12:48 PM - Thread Starter
Also, I'm looking for quality glass fiber optical cable,not plastic
post #3 of 9 Old 04-09-2011, 12:54 PM - Thread Starter
Doing it now but thought someone might help point in the right direction. That's what forums are for dude.Relax.
post #4 of 9 Old 04-09-2011, 04:28 PM
MrBobb's Avatar
Quoted: 165 Post(s)
Liked: 63
Hey man, ur gonna run it across 2 rooms, not across town, but whatever.
MrBobb is offline
post #5 of 9 Old 04-09-2011, 04:51 PM - Thread Starter
The length is not the factor dude, the quality of the cable is. Glass is simply better than plastic when it comes to fiber optic.
post #6 of 9 Old 04-09-2011, 07:18 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
[SARCASM]And Monster is simply better than Blue Jeans when it comes to cable [/SARCASM]
http://www.google.com/search?rlz=1C1...eebd71ad7825d5
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is online now
post #7 of 9 Old 04-13-2011, 08:48 AM
KingLeerUK's Avatar
Liked: 75
While your statement is true, when working with the distances typically involved in home theatre audio (in your case 50 feet) the "conductor" material choice is a bit trivial. At 50 feet a decent quality PoF will yield the same audible and measurable results as a GoF for orders of magnitude less in price. So long as the PoF is undamaged and of reasonable quality, your 1's and 0's will reach their destination unmolested.
I speak from experience. I have Monoprice Toslink cables in my installation; one run of 65 feet and another of 35 feet and both perform as well as "premium" shorter length cables.
If you simply have a desire to spend money frivolously, then by all means go with GoF, but I would not expect to hear anything differently except the echo from the void in your wallet...
KingLeerUK is offline
post #8 of 9 Old 04-20-2011, 05:16 PM
eatdapoopoo's Avatar
This should more than meet your needs. No need to spend any more.
eatdapoopoo is offline
post #9 of 9 Old 04-20-2011, 08:34 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
Originally Posted by MonoPrice View Post
...w/ Metal Fancy Connector
Yup. That's mah kinda cable.
Reply Tweaks and Do-It-Yourself
