Laptop image to TV over LAN - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 05-28-2011, 11:29 AM - Thread Starter
mucho77's Avatar
Hello all
I am trying to display my Laptop image on the TV via Wireless/LAN.
Think of the TV as the projector without the cable.
Now If do have a Samsung UE46D6510 TV. There are quiet a few screensharing ads out there and perhaps the TV has to support that too. I am hoping for a trick of hack here.
Thanks for your support
mucho77 is offline
post #2 of 8 Old 05-28-2011, 02:37 PM
MrBobb's Avatar
Quoted: 164 Post(s)
Liked: 63
are u looking for a static (once-off) capture? continuous video? or something in between like a new picture every 5 sec enuff? And how much are u budgeted for?
MrBobb is offline
post #3 of 8 Old 05-29-2011, 03:09 AM - Thread Starter
mucho77's Avatar
Hi!
basically the TV should be a second monitor/beamer and I want to stream a picture there. moving, motion not with 5sec interval. Sound is not so important.
best example, surfing the web on the large TV without connecting a cable.
if it works, budget does not matter.
thanks
mucho77 is offline
post #4 of 8 Old 05-29-2011, 10:37 AM
MrBobb's Avatar
Quoted: 164 Post(s)
Liked: 63
Pay sumbody to write a VNC widget for the Samsung. Anything else requires the addition of external hardware.
MrBobb is offline
post #5 of 8 Old 06-03-2011, 01:20 PM
bloodyguitars's Avatar
Perhaps Intel WiDi (Wireless Display) is what you are looking for.
Newer laptops come with the chip built-in, but you can also get the part and replace it yourself. You would then need the Netgear Push2TV Adapter to connect to your TV.
V
bloodyguitars is offline
post #6 of 8 Old 06-16-2011, 10:08 AM
HoustonWKV's Avatar
would wireless hdmi work?
HoustonWKV is offline
post #7 of 8 Old 06-17-2011, 07:52 AM
Dj Co2's Avatar
there's no wireless hdmi in Samsung UE46D6510.. I had a vnc program written for this purpose
Best Laptops 2010
Dj Co2 is offline
post #8 of 8 Old 06-17-2011, 09:55 AM
HoustonWKV's Avatar
No I meant you could buy a wireless hdmi adapter
http://www.google.com/products/catal...ed=0CE0Q8wIwAQ
like this one
Reply Tweaks and Do-It-Yourself
