Surge protector? How with a mounted plasma? - AVS Forum | Home Theater Discussions And Reviews
Old 07-24-2011, 11:27 PM - Thread Starter
dasanii19's Avatar
Quoted: 116 Post(s)
Liked: 30
My plasma is mounted on the wall, I relocated the outlet so that I wouldnt have any wires hanging down. Now im wondering how I can protect my tv from surges being that I now have limited space behind the TV? I did see this on amazon.. http://www.amazon.com/Tripp-Lite-SPI...1571663&sr=1-3 .. would this help at all? My plasma is a samsung 59" 6500 series.
Help... please.
MY NAME IS SUE!!! HOW DO YOU DO!!!
"I started out with nothing, and I still have most of it."
dasanii19 is offline
Old 07-25-2011, 12:49 AM
MrBobb's Avatar
Quoted: 164 Post(s)
Liked: 63
Fine. Got a $5,000 warranty, so go4rit.
MrBobb is offline
Old 07-25-2011, 08:56 AM - Thread Starter
dasanii19's Avatar
Quoted: 116 Post(s)
Liked: 30
Is 540 Joules enough for my tv?
Old 07-25-2011, 09:24 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Leviton offers a surge protected outlet as well, for $30. I'm putting one into my low voltage enclosure.
I haven't read of anyone collecting on those warranties.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
Old 07-25-2011, 09:58 PM
Colm's Avatar
Liked: 94
Joule ratings are hard to compare because there are no industry standards. The most a Type 3 device like this is expected to see is 90J assuming there us at least 30 feet of wiring between the receptacle and the panel. The UL rating is 500V VPR and 3kA In. Should be just fine.
Just be aware that protecting the AC is only part of the problem. All conductive paths into the TV (antenna, cable, video, audio) needs to be protected. Best approach is a whole-house approach.
Colm is offline
Old 07-27-2011, 12:36 PM
MrBobb's Avatar
Quoted: 164 Post(s)
Liked: 63
There are probly tons of "gotchas" in the fine prints.
MrBobb is offline
Old 07-27-2011, 12:52 PM
video321's Avatar
Quoted: 21 Post(s)
I have a protector in my equipment closet that protects all of my TVs in the house. All TV receptacles are tied back to this location and I use an inlet to provide power. Just another option since you mentioned being able to move receptacles.
video321 is offline
Old 08-06-2011, 01:00 PM
oppopioneer's Avatar
SurgeX makes a compact surge protector for flat planel displays you can mount to the back of the display if you want. I use the SurgeX XF2 FlatPak for my Pioneer plasma...
www.surgex.com/pdf/XF2-LR.pdf
or...
SA82 FlatPak http://surgex.com/products/sa82FlatPak.html
http://i453.photobucket.com/albums/q.../SurgeXXF2.jpg
http://i453.photobucket.com/albums/q...os/SurgeX1.jpg
oppopioneer is offline
