DIY 3.5mm cable - AVS Forum | Home Theater Discussions And Reviews
Old 07-26-2011, 02:14 AM - Thread Starter
Evildude's Avatar
Quoted: 31 Post(s)
Hi guys I wondering if any of you know how to make this type of cable.
I've gotten that same cable 3 times from monoprice but it keeps failing on me in the exact same way!! one of the channels eventually starts cracking and then goes off...
So I was thinking of buying a thicker cable somewhere else or just making one myself..
Evildude is offline
Old 07-26-2011, 08:18 AM
SAM64's Avatar
Liked: 78
Maybe it's the female connector?
SAM64 is offline
Old 07-26-2011, 08:44 AM
ericspencer's Avatar
You can make your own .. you'll need some decent quality 2 conductor shielded cable .. and the two connectors, but honestly I think you could do it cheaper by just buying a higher quality cable like this one . Those cheap cables always seem to fail at some point and we no longer use them in any install, its not worth the call back headache and expense, so buying a better cable from the start tends to cost us less.
ericspencer is offline
Old 07-26-2011, 02:13 PM - Thread Starter
Evildude's Avatar
Quoted: 31 Post(s)
Sweet!
Look mi sofa is around 14ft from the receiver, a straight shot nothing on the way and nothing pinching the cable..and I do not move as Im using it..I just use it to extend the cable of my headphones while I play video games at night that's all. Is that place reliable to buy from?
Evildude is offline
Old 07-26-2011, 03:03 PM
Originally Posted by Evildude View Post
Sweet!
I think so .. we use a lot of their product and quality has never been a issue
Old 07-27-2011, 12:38 PM
MrBobb's Avatar
Quoted: 164 Post(s)
Liked: 63
cables fail often in mobile applications because you are always twisting, bending, stressing it, but if a fixed cable fail u multiple times... something else is wrong.
MrBobb is offline
