Power extension cords - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-28-2011, 08:42 AM - Thread Starter
sam008's Avatar
Guys
I could not find a place to put this and hoping someone here knows the answer
Does anybody know of any extension cords that show the live power usage similar to how kill-a-watt does it? I thought I'd see one in the past
If you don't know, can you please recommend a good extension cord with maybe 2 outputs at the end? Many of the ones I see have very thick cables and not looking for that
sam008 is offline
post #2 of 3 Old 07-28-2011, 09:26 PM
MrBobb's Avatar
Quoted: 165 Post(s)
Liked: 63
There is a kill-a-watt power strip, but yeah, does that thick cord.
MrBobb is offline
post #3 of 3 Old 07-28-2011, 09:49 PM
investmentcar's Avatar
I've plugged power strips into my kill a watt to see how much wattage my HT uses. (~90 standby, highest peak i have seen was ~490 watts. Sub not included.) Would that work?
A little more detail: I have 18" power cord, kill a watt, then power strip. This way it doesn't block the recep and I can see the display...
investmentcar is offline
Reply Tweaks and Do-It-Yourself
