Speaker wire and sub cable in same conduit? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-17-2012, 10:18 AM - Thread Starter
Spaceman's Avatar
Quoted: 41 Post(s)
Liked: 139
Is it ok to run sub cable (RG6) in the same conduit as regular speaker wire?
Spaceman is offline
post #2 of 10 Old 01-17-2012, 12:21 PM
tomscave's Avatar
It's ok to run those together. Do not run electrical in the same conduit.
"I'm suffering from the dreaded upgrade bug"
tomscave is offline
post #3 of 10 Old 01-18-2012, 07:46 AM
Wayne A. Pflughaupt's Avatar
Quoted: 88 Post(s)
Liked: 67
Any low voltage can be run in the same conduit – speaker, RF coax, phone, cat5, HDMI, etc. You just can’t run low and high (electrical) voltage in the same conduit.
Wayne A. Pflughaupt
Equipment List
"A nice mid-fi system," according to an audiophile acquaintance.
Reviews and Tech Articles
Wayne A. Pflughaupt is offline
post #4 of 10 Old 01-19-2012, 03:17 AM
Speed Daemon's Avatar
Quoted: 91 Post(s)
Liked: 47
Local ordinances, electrical and fire codes vary widely. Better to be safe and check with the authorities first.
You get what you pay for.  For professional advice, pay the professional rate.
Speed Daemon is offline
post #5 of 10 Old 01-19-2012, 02:36 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
A related question - why don't AC currents from 'LV' phone affect adjacent speaker wires? The phone AC current jumps to 90 VAC, while ringing.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #6 of 10 Old 01-19-2012, 03:27 PM
SAM64's Avatar
Liked: 78
Current is measured in Amperes, Potential difference in Volts.
Magnetic flux is directly proportional to current.
The current flowing when the phone rings is small, very little magnetic flux.
Speakers are low impedance devices, inducing enough curreent into a low impedance circuit to be audible is very difficult.
SAM64 is offline
post #7 of 10 Old 01-19-2012, 07:20 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Ah, yes. From Sandman's site, I see it's 35 mA. Thanks.
Neurorad is offline
post #8 of 10 Old 01-21-2012, 02:04 PM
Quoted: 91 Post(s)
Liked: 47
Both phone cord and speaker wire are packaged so that each pair is parallel and very close together. This rejects common mode noise, and keeps EM emissions to practically zero. Unless that phone cable is driving a high REN load, the amount of power is miniscule. A cordless phone base of the type that is common with whole house cordless products has a REN that's 1/10th that of an old Western Electric phone. Besides, how often does the phone ring?
If the phone ringing made a noise that I could hear through my speakers, I'd call that a feature!
post #9 of 10 Old 02-08-2012, 10:11 AM
obscuremind's Avatar
how far apart should I space the conduit to the electrical wire and the conduit to holding my speaker wires? would a foot be plenty enough? or would that even matter?
obscuremind is offline
post #10 of 10 Old 02-15-2012, 03:55 PM
tomscave's Avatar
Minimum is 4".... A foot apart would work fine.
tomscave is offline
Reply Tweaks and Do-It-Yourself
