Help a dummy - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-10-2012, 06:20 AM - Thread Starter
SA Stranger's Avatar
Ok, so I am an old fart trying hard to set something up for the kids in the spare room. I know I am a dummy, so no need to call me one
I have a Sansui plasma SV -EPD-4230BP and a Sansui AU-X410R Amp
Is it possible to connect an amp direct to the tv, if so, what cable goes where. I have tried a few combinations and nada. I have both manuals, but hell even the writing has gotten smaller since I last read them.
please assist if you can
regards
SA Stranger is offline
post #2 of 5 Old 04-10-2012, 07:27 AM
dharel's Avatar
Liked: 33
What exactly are you trying to accomplish? Is the TV being fed anything like cable, satellite, dvd, blu-ray, etc?
dharel is offline
post #3 of 5 Old 04-10-2012, 07:47 AM
Neurorad's Avatar
Quoted: 227 Post(s)
Liked: 145
I think you need to invest in a magnifying glass, and spend a few hours reading through the manuals. With age, tech becomes more frustrating, I think mostly because of impatience.
I'm guessing Sansui is a brand name? Most TVs don't require an external amp - are you attaching speakers?
There may be a setting in the TV menus/setup that allows the external audio jack to function, to use that external amp.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #4 of 5 Old 04-10-2012, 03:21 PM
MrBobb's Avatar
Quoted: 165 Post(s)
Liked: 63
Sansui - wow, havent heard that brand in like 30 years.
Simple as water: AUDIO OUT to AUDIO IN.
AUDIO OUT can also be Earphones.
AUDIO IN - there will be many in an amp, pick one, then switch your amp input accordingly.
Make sure everything is POWERED ON.
MrBobb is offline
post #5 of 5 Old 04-17-2012, 05:43 PM
ELECTRICDON's Avatar
Had to read just because of the title. Need further explanation of what is trying to be achieved. Gl.
ELECTRICDON is offline
Reply Tweaks and Do-It-Yourself
