IEC Mod to Denon AVR2800 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-02-2012, 11:43 AM - Thread Starter
pahhhoul's Avatar
I just purchased a Denon AVR2800.
Why?
Because it was the silver chassis version
and I picked it up for only $70.
It currently has a 2 prong power cord plug
I seen a mod'd AVR2800 with this power cord online yesterday!
And now I want to do the same for some DIY fun!
Now my questions.
1.Since there is only a positive and negative coming from the connector from the board, can I still add a 3 prong IEC male socket to the chassis of the unit?
2.If so, what about that 3rd wire that's in a 3 prong IEC power cable?
Paul
Oakland, CA
HT buff since 1992. = )
pahhhoul is offline
post #2 of 7 Old 05-02-2012, 03:09 PM
SAM64's Avatar
Liked: 78
What are you hoping to accomplish with this?
SAM64 is offline
post #3 of 7 Old 05-03-2012, 11:08 AM - Thread Starter
pahhhoul's Avatar
this is purely for fun.
Paul
Oakland, CA
pahhhoul is offline
post #4 of 7 Old 05-03-2012, 08:45 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 911
There is no positive and negative. It's hot and neutral. The third wire is a 'grounding' or 'earthing' conductor. It attaches to that large metal thing called the 'chassis'. If I were you, I'd consider having someone who knows these things perform the modification for you. You are dealing with potentially dangerous stuff there.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #5 of 7 Old 05-04-2012, 07:12 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
1. Yes, it can be dangerous. If you miswire, or short, it could burn your house down.
2. Can you just wrap the existing power cord? It could look nearly identical.
3. If you terminate the cable yourself, you could use a 2 conductor power cable. But there is a danger that someone else in the future might use it for another component, if you get hit by a truck or something. No way to tell that the ground conductor is absent.
If you knew what you were doing, it would be easy to use an IEC socket, and just leave the ground terminal disconnected at the component, and use a standard IEC cable. But you could screw it up, and kill someone.
You really shouldn't add a grounded socket to the back of the AVR, if it's not grounded.
You could physically defeat the ground hole on the socket so a standard IEC cord couldn't be used.
Seems like a lot of risk and trouble for no benefit.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #6 of 7 Old 05-04-2012, 11:58 AM - Thread Starter
pahhhoul's Avatar
thanks for the input.
after reading the above info, I've just decided to dress up the current cord with some techflex and nicer looking 2 prong plug and call it a day.
thanks everyone!
Paul
Oakland, CA
pahhhoul is offline
post #7 of 7 Old 05-04-2012, 04:13 PM
MrBobb's Avatar
Quoted: 164 Post(s)
Liked: 63
The nice dress doesn't match the bride! This cable wants to be with a 200LB Conrad Johnson.
MrBobb is offline
Reply Tweaks and Do-It-Yourself
