RG6 for subwoofer cable. 2 runs or split one? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-02-2012, 04:37 PM - Thread Starter
CanadianZ's Avatar
I have used RG6 cable with an F to RCA connector on the end for a number of installs. I wanted to wire my new install theater with 2 locations for my subwoofer. Either to have one at the best of two locations or to run two subs in the future.
Can I use a regular cable splitter at the first location and continue the run after the splitter to second location??
---1st Sub
Line from receiver -------------------[splitter
----------------2nd sub
Thanks, Tony
CanadianZ is offline
post #2 of 7 Old 05-02-2012, 05:55 PM
fcwilt's Avatar
Quoted: 43 Post(s)
Liked: 26
Depends on what you mean by "regular cable splitter".
Regards, Frederick C. Wilt
fcwilt is offline
post #3 of 7 Old 05-02-2012, 07:08 PM - Thread Starter
CanadianZ's Avatar
Well, what kind of splitter should I get or what specs should I lookfor??
Will there be any signal loss or delay to the second sub??
Tony
post #4 of 7 Old 05-02-2012, 08:55 PM
fcwilt's Avatar
Quoted: 43 Post(s)
Liked: 26
Well you could use something like this for RCA connectors:
http://www.audioadapter.com/cgi-bin/...&preadd=action
The type of "splitter" used for TV type signals is NOT what you are looking for.
fcwilt is offline
post #5 of 7 Old 05-03-2012, 09:52 AM
jackbuzz's Avatar
"The type of "splitter" used for TV type signals is NOT what you are looking for."
Just wondering, if a RG6 cable can send AV signals all around the city to homes, be split and deliver an acceptable signal, what would be lost content wise if someone substituted a TV splitter for typical Y splitter, on a sub cable using RG6?
jackbuzz is offline
post #6 of 7 Old 05-03-2012, 11:44 AM
SAM64's Avatar
Liked: 78
The loss would be 100% since an RF splitter generally has a high pass filter at 50MHz, and audio tops out at 20KHz.
SAM64 is offline
post #7 of 7 Old 05-04-2012, 06:58 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Why would you daisy chain, and not run both cables back to the equipment? Running both cables back gives you the option in the future to use 2 amps.
With both cables run back, use the splitter at the equipment.
Also, consider other locations where you may ever want a sub, and run cable there too, unterminated behind the drywall. Take pictures.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
Reply Tweaks and Do-It-Yourself
