Power cables? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-06-2012, 09:22 PM - Thread Starter
Mad Bomber's Avatar
I've been doing research on power cables and the humm you can get along with good ends that don't break the bank. What cable and ends would you recomend?
Mad Bomber is offline
post #2 of 7 Old 06-07-2012, 06:03 AM
ccotenj's Avatar
Liked: 101
the one that came with the piece of equipment...
Gizmologist likes this.
- chris
ccotenj is offline
post #3 of 7 Old 06-07-2012, 04:20 PM
Colm's Avatar
Liked: 94
+1
There is a thread up in the audio forum all about this. No use repeating it here.
Colm is offline
post #4 of 7 Old 09-09-2012, 09:22 PM
Tnilsson's Avatar
Liked: 25
If you are thinking of buying separate power cables, you have not done enough research yet. Keep researching until you learn that it's a silly idea.
Tnilsson is offline
post #5 of 7 Old 09-10-2012, 05:56 PM - Thread Starter
Mad Bomber's Avatar
That's what I had assumed by my research waste of money
post #6 of 7 Old 09-16-2012, 01:51 PM
Glimmie's Avatar
Quoted: 732 Post(s)
Liked: 592
The "ends" or connectors all of these esoteric power cords are nothing more that stock electrical parts available at any electrical supply house, even home centers. Now they are what is knows as "specification grade" which is another way of saying commercial grade and they do cost more than residential grade parts. That said a good specification grade plug may retail for $10 while a residential grade may sell for $3.
These snake oil companies know this so that is why they resort to gold plating and cryo treating these commodity off the shelf parts. It's just BS to get more money out of you. Furthermore the modification of a UL listed product to be resold is illegal in many jurisdictions.
Anything Wattgate sells can be purchased at an electrical supply house at a fraction of what they charge. Now you won't get the gold plating, cryo treatment, and all the other magic pixi dust they sprinkle on, so you be the judge.
Glimmie is offline
post #7 of 7 Old 09-16-2012, 05:56 PM
Colm's Avatar
Liked: 94
Originally Posted by Glimmie View Post
...a good specification grade plug may retail for $10 while a residential grade may sell for $3.
Frankly, a residential grade plug will work as well as a spec grade plug. However, if anyone wants to spec money upgrading their power connection, I would recommend replacing residential grade receptacles with spec grade or hospital grade receptacles, just because they grip better.
Colm is offline
Reply Tweaks and Do-It-Yourself
