Component Location Ideas? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-25-2012, 02:26 PM - Thread Starter
balinton's Avatar
Hi All,
New to the forum just bought our first house and I am starting to setup my AV equipment. I have a 50" Samsung Plasma mounted with a Large full motion Sanus Mount. I am trying to figure out the best location for mounting the components. Currently I have a Blu ray Player a Comcast HD DVR and a Denon AV Reciever with a Boston Acoustics 5.1 speaker setup. I am unable to position anything below the tv due to the relation of the coach to the wall so the only options I see are to the left, right or top of the tv on a wall mount but my wife does not like this idea and would rather the equipment not be seen. I could run the equipment from the basement I am just not familiar with the logistics of having the AV equipment this far away from the operating environment so I am up for any ideas, thoughts and or questions...
Picture of tv mounted on wall.
450
Brandon
Brandon Linton
Mini Penn Cinema HT Build 1.0
balinton is offline
post #2 of 6 Old 06-25-2012, 07:25 PM
AV Doogie's Avatar
You can set this up any way you wish. IMHO, a media player in a separate room is a pain. You need nearby access to a DVD/BluRay player to change discs.
Remote location of Satellite tuners works fine.
Do you have a closet within this room?
My Home Theater Site:
DJ-Theater
AV Doogie is offline
post #3 of 6 Old 06-25-2012, 08:20 PM - Thread Starter
balinton's Avatar
Unfortunately no closet near by I was thinking the same thing for the DVD and possibly the other components... I am really considering using a wall mount like the one below... Anyone use one of these for mounting components on the side of a tv or have recommendations?
http://www.amazon.com/Sanus-VF2012-B1-Wall-Mounted-Furniture-Component/dp/B001ED52R8/ref=sr_1_1?ie=UTF8&qid=1340677053&sr=8-1&keywords=sanus+component+rack
Brandon
Brandon Linton
balinton is offline
post #4 of 6 Old 06-27-2012, 12:02 PM
AV Doogie's Avatar
I have a unit like this mounted in my basement rec. room location. They work well if the wiring channel is large enough to accommodate your requirements. I would also make sure the shelving can handle the weight of your equipment.
DJ-Theater
post #5 of 6 Old 06-27-2012, 12:05 PM - Thread Starter
balinton's Avatar
well I just decided to buy the Cheetah mount 3 rack shelf so we will see how the wife likes it... Looks like the most logical decision.
Brandon
Brandon Linton
balinton is offline
post #6 of 6 Old 07-04-2012, 06:53 PM
MrBobb's Avatar
Quoted: 165 Post(s)
Liked: 63
A side cabinet with a smoke door which doubles as a plant stand?
That's a weird location for the TV considering the placement of that couch.
MrBobb is offline
Reply Tweaks and Do-It-Yourself
