Need a smart strip replacement - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-05-2012, 03:16 PM - Thread Starter
Jerry Parker's Avatar
I've used a smart strip autoswitching power strip for the past several years. I use my av receiver to controll a digital crossover and three profound amps.
The entire time I've had it, it worked marginally. For a week or two it would work. Then I would switch the receiver off, and it would take 5 minutes to turn the amps off.
Recently it started not switching the devices off at all.
Can anyone reccomend a device to replace it with that will actually work? I'd like to spend less than 50$ if possible.
Jerry Parker is offline
post #2 of 5 Old 07-06-2012, 03:40 PM
Wayne A. Pflughaupt's Avatar
Quoted: 88 Post(s)
Liked: 67
For that price? Nothing I would plug a power amp into.
Wayne A. Pflughaupt
Equipment List
"A nice mid-fi system," according to an audiophile acquaintance.
Reviews and Tech Articles
Wayne A. Pflughaupt is offline
post #3 of 5 Old 07-12-2012, 07:13 AM
AV Doogie's Avatar
If you have the capability, you can build one yourself.
I have used two DIY units in my rack to switch amplifiers for years...
My Home Theater Site:
DJ-Theater
AV Doogie is offline
post #4 of 5 Old 07-13-2012, 04:55 AM
Bernard Emby's Avatar
You can use one of our Advanced PowerStrips. A lot of AV folks use our 12 outlet unit because it has high surge protection ratings. If you have a smaller system you can use the 7 outlet item - works in exactly the same way.
http://www.tricklestar.com/us/index.php/products-1/advanced-powerstrips.html
Cheers
Bernard
Bernard Emby is offline
post #5 of 5 Old 07-13-2012, 08:22 AM
AV Doogie's Avatar
Those look like nice Products....do they have UL 1449 or similar ratings?
DJ-Theater
Reply Tweaks and Do-It-Yourself
