Newbie Question: What do I need to buy: RG59 Cable for subwoofer? - AVS Forum | Home Theater Discussions And Reviews
Old 10-14-2012, 08:59 PM - Thread Starter
sksahai's Avatar
Hello!
IF this is a repost, please kindly refer me to the appropiate thread.
I have a new house and media room, prewired for 7.1. I just hung the projector yesterday night. I need to hookup my subwoofer.
I have behind the wall plate (at both ends) a RG59 20AWG cable for the subwoofer. Just the cable, chopped off, no connectors, no RCA connectors, no nothing, just the cable.
In order to hook up my sub, what do I need and how do I go about doing it?
I have searched the forums and I think I am using the wrong terms. I need the idiots's guide.
I have multiple little coax male/male adpaters (I pulled them off the coax wall plates to make room to pass my speaker wires through).
I think I need a crimping tool, plus some sort of connector to attach the RG59 to an female RCA plug that then plugs into the Subwoofer and AVR.
I ran across this:
http://www.pimfg.com/ifaq/crimpfaq.htm
Is that it?
If so, what do I search for either at monoprice or partsexpress?
What if I want to have the RG59 terminate in the wall plate, and then have the subwoofer line in plug into the wall plate. Is it any different?
sksahai is offline
Old 10-15-2012, 08:58 AM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
I would do (have done) F connectors on the Series 59 cable, with a short piece of 59 going from the wallplate to the device, with an adapter (FF-R) to plug it into the AVR and the sub-woofer.
CIAO!
Ed N.
egnlsn is offline
Old 12-08-2012, 09:53 AM - Thread Starter
sksahai's Avatar
Could you be so kind to let me know what I need? Is it a F type to RCA Female or F Type to RCA Female. I have a standard subwoofer, and it has the "female" plug on it (so does the receiver) Subwoofer cables have male tips at both ends. I searched monoprice and did not find a Ftype to RCA connector.
Sunil
sksahai is offline
Old 12-08-2012, 01:26 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Originally Posted by sksahai View Post
Hello!
I ran across this:
Is that it?
Looks good. Compression fittings are the modern solution and give me great performance.
The tutorial is a little tool-happy. I have great results with just a stripping tool and a compression tool.
The plastic compression tools seem to work out. I've used them and I noticed that the cable guy used one when I switched to Wowway.
They need to be sized for the cable, so don't try to use RG59 compression fittings with RG6 and vice-versa.
rca compression
http://www.parts-express.com/pe/showdetl.cfm?partnumber=092-496
Get a bulkhead RCA jack
http://www.parts-express.com/pe/showdetl.cfm?partnumber=091-1210
Drill an appropriate hole in the blank wall plate of your choice.
arnyk is offline
Old 12-11-2012, 05:34 PM
DoyleS's Avatar
Quoted: 35 Post(s)
Liked: 25
All of the connectors and adapters you need are available at Radio Shack. Female-Female F connector on the wall plate. F connector Male on the Cable in the wall. F Connector Male to RCA Female adapter on the end of an RCA Male to RCA Male cable for connecting between the Sub and the Wall plate. Pretty straightforward stuff.
M&K S150THX LCR, SS150THX Tripoles, 4 Speakercraft Aim-7 for Atmos
B&K AV5000 driving the M&Ks
Denon X4300H AVR
"So many tweeks....So little time!"
DoyleS is offline
Old 12-11-2012, 11:03 PM - Thread Starter
sksahai's Avatar
Thank you! Going to be a Xmas break project!
sksahai is offline
Q See 1000ft Rg59 Cable , Q See 500ft Rg59 Cable
