New electric projector screen-can you switch the side the power cord is on? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-07-2012, 10:33 AM - Thread Starter
Ascinder's Avatar
I haven't been able to find much info about this and the "manual" that came with this screen, but I rember seeing somewhere that it is possible to switch the side of the screen that the power/control cord falls on. Any guides out there on this, is it only on certain screens, etc. I tried searching but came up with nothing.
Ascinder is offline
post #2 of 3 Old 12-07-2012, 12:20 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
I've replaced the screen on a motorized projection screen, and have probably done most if not all of the steps required.
BTW you may have to remove the screen from the roller along the way.
My first reaction is that what you want to do is a lot of work for any good that you might obtain.
If you want to see the parts of the screen to help you work out your strategy, here is a drawing showing them all:
http://www.da-lite.com/products/parts_pdfs/299.pdf
arnyk is offline
post #3 of 3 Old 12-07-2012, 01:17 PM - Thread Starter
Ascinder's Avatar
Huh, thanks for the info. I thought I remembered coming across some instructions for switching the side the cord was on and it seemed very easy. Almost like: just remove the endcaps and swap the power control circuit board from one side to another. Since mine has motors on both sides, the power is already run across. I can't for the life of me remember where I saw those instructions though. I just don't want to grenade a brand new screen because I missed something simple.
Ascinder is offline
Reply Tweaks and Do-It-Yourself
