Trying to find Audio Cables behind Sheetrock - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 12-10-2012, 03:42 PM - Thread Starter
TallMinnesota's Avatar
I have not been able to find an answer as to the best "tone generator" to connect to the ends of audio wires for locating wires installed prior to sheetrock. I can access one end of the wiring but have no idea where they run.
TallMinnesota is offline
post #2 of 11 Old 12-10-2012, 04:20 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
I think that you are looking for something like this:
http://www.amazon.com/Extech-40180-Generator-Amplifier-Circuit/dp/B00023RVNO
arnyk is offline
post #3 of 11 Old 12-10-2012, 05:13 PM - Thread Starter
Unfortunately this product does not read the sound through a sheet of sheetrock.
post #4 of 11 Old 12-11-2012, 04:40 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Stud detectors are actually a kind of metal detector. While they work best with ferrous metals, their inductive operating principle can work with metal wires that are not even hooked up.
Devices like the one I mentioned can sometimes pick up the signal injected into the wire by means of capacitance to their probe tip.
Unless you know that wires were orphaned in the walls, it is highly probable that both ends are exposed someplace.
The telephone and cable guys use tools like the one I pointed out.
arnyk is offline
post #5 of 11 Old 12-11-2012, 01:09 PM
Wayne A. Pflughaupt's Avatar
Quoted: 118 Post(s)
Liked: 86
I can tell you from experience that a tone generator / probe will not work with shielded audio cable. The shield works in both directions!
Wayne A. Pflughaupt
Equipment List
"A nice mid-fi system," according to an audiophile acquaintance.
Reviews and Tech Articles
Wayne A. Pflughaupt is offline
post #6 of 11 Old 12-11-2012, 03:14 PM - Thread Starter
The cable I am tracing is regular cheap two strand, stranded speaker wire. I found a $70 "Fluke 3000 Analog Tone & Probe Kit" at Home Depot which appears to be working quite well in reading the wire when connected on one end with the alligator clips. It reads through sheetrock and finished wood bookcase material. Thank you for your thoughts.
post #7 of 11 Old 12-12-2012, 04:52 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Wayne A. Pflughaupt
The common circumvention is to clip the signal generator to the shield.
arnyk is offline
post #8 of 11 Old 12-12-2012, 04:55 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
If this is what you obtained:
Then you got a great deal!
Technically the same thing as I recommended but obtained quickly from a local source for a great price. I'll file that little piece of knowlege away... ;-)
arnyk is offline
post #9 of 11 Old 12-12-2012, 06:59 AM - Thread Starter
That is the one. I bought it, installed two 9 volt batteries (one in each unit) and it works very well. I do not know how far behind the sheetrock the wire is but it reads the wire well.
post #10 of 11 Old 12-12-2012, 01:19 PM
Quoted: 118 Post(s)
Liked: 86
Ah, of course. Shoulda known that if Arny said it would work, that it indeed would! smile.gif
By the way, I was in the Grosse Point area in August. Nice place!
Wayne A. Pflughaupt
Equipment List
post #11 of 11 Old 12-12-2012, 01:45 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
I appreciate the confidence and hope I'll never let anybody down.
Hate to be a perfectionist about it, but it is spelled Grosse Pointe. ;-)
arnyk is offline
Reply Tweaks and Do-It-Yourself
