using laptop as electronic guard dog - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-11-2012, 09:12 AM - Thread Starter
huggybear404's Avatar
I have an old laptop running windows 2000 and im looking for software to trigger a mp3 file of angry dogs when it hears a sound.
The lap has internal mic that is quite sensitive and a whopping 64 mb of ram which is sadly the max this box can support. also a 300 mhz celeron.
so im looking for any software that can detect a sound on the mic input and trigger an mp3 or wav file , then it needs to wait for the file to play to the end and start listen for sounds again. it should run in less than 10 mbs of ram if possible.
I can also install linux if there is any program for linux that can do this.
is there anyone who has tryed to build an electronic dog to scare burglars ?
do they work ? and who has suggestion to a program that can trigger the mp3 ?
is this something that I can make easy in visual basic ? if so how ?
huggybear404 is offline
post #2 of 2 Old 01-05-2013, 09:49 PM
anand1234's Avatar
recommend use motion sensors and then trigger the mp3 files.
U can even use the parallel port to receive the input and can be done
with VB or java as u wish.
Triggering from microphone is also possible but i cant figure out
an operational concept on where the mic will be and what kind
of sounds needs to be picked up and how far all this will lead
to false alarms.
let me know if u need any help with getting triggers via the
parallel port.
anand1234 is offline
Reply Tweaks and Do-It-Yourself
