SURGE PROTECTION RECOMMENDATIONS NEEDED FOR A NEWBY WITH A RELATIVELY SIMPLE SYSTEM!!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-18-2013, 05:41 PM - Thread Starter
tazbom's Avatar
I just finished an entertainment center and have mounted a 65 inch Samsung un65es8000. I need to know what kind of surge protection I need for a relatively simple system. I will eventually have the tv, blu ray, game console, and sound system plugged into it. What is it that I need? Any help is much appreciated. Thank you.
tazbom is offline
post #2 of 4 Old 01-21-2013, 09:07 PM
Phil17108's Avatar
Quoted: 207 Post(s)
Liked: 108
3 days and no help. What I am using is a Panamax power conditioner / surge protector. Have 2 now for about 8 years and don't know they are there and I guess thats about the best thing I can say about it, it works. What you need to do is look at the watt's or amp draw of your system and get one that can handle about 50% more then your system pulls.
Phil17108 is offline
post #3 of 4 Old 01-22-2013, 05:38 PM
Speedskater's Avatar
Quoted: 20 Post(s)
After almost 4 days and no one has posted that a whole house system is by far the best way to go,
Kevin
Speedskater is offline
post #4 of 4 Old 01-22-2013, 08:12 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
Probably because there are over 3 thousand threads about it according to a simple search of 'whole house surge'.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
Reply Tweaks and Do-It-Yourself
