Looking for a good ground in/ner my AV cabinet for APC ProtectNet surge protector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-02-2013, 10:09 AM - Thread Starter
metropole's Avatar
Quoted: 39 Post(s)
I have an APC ProtectNEt surge protector to protect my network going into the AV cabinet:
http://www.apc.com/resource/include/techspec_index.cfm?base_sku=pnet1gb
It needs to be grounded.
I have an (older) Panamax Max4300. However, it doesn't have a grounding screw.
It has the typical anodized finish.
I am looking for some ideas for the ground. Or just wire it to thepower outlet?
metropole is offline
post #2 of 2 Old 02-02-2013, 02:37 PM
Colm's Avatar
Liked: 94
You can connect the ground wire to equipment that has a grounded case (3-prong plug) or to the building equipment grounding conductor. Assuming you have properly grounded electrical receptacles, the easiest way to do the latter might be to use the screw that holds the plate to the receptacle. It needs to be bare metal where it touches the spade lug, of course.
Colm is offline
Reply Tweaks and Do-It-Yourself
