VGA cable soldering - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-13-2013, 06:57 PM - Thread Starter
CPDesign's Avatar
Hey All,
I recently was given the task of creating some VGA cables from scratch with West Penn 5CRGB cable and normal DB15-HD solder type connectors, but for the life of me I cannot get the cables to work, though I have tested continuity, The cable has 5 coaxial cables inside.
I am doing the following:
1 - Red
2- Green
3 - Blue
4- nothing
5- Hsync GND
6- Red GND
7 - Green GND
8 - Blue GND
9 - nothing
10 - Vsync GND
11 - nothing
12 - nothing
13- Hsync
14- Vsync
15 - nothing
Any ideas? Can I combine grounds? What about pins 4,11,12,15?
--CP
CPDesign is offline
post #2 of 3 Old 02-15-2013, 01:54 PM
jautor's Avatar
Quoted: 1336 Post(s)
Liked: 855
Probably a lot easier to just terminate the coax cables with BNC connectors and use a BNC-to-VGA adapter:
http://www.monoprice.com/products/product.asp?seq=1&format=2&p_id=566&CAWELAID=1329450816&cagpspn=pla&gclid=CJfIu6GmubUCFUWd4AodBl8Alg
Do that at both ends and you're done. (Check gender on the connectors)
Jeff
NOTE: If you find dead photo links in any of my posts, please PM me and I will fix it.
jautor is offline
post #3 of 3 Old 02-15-2013, 11:29 PM
Colm's Avatar
Liked: 94
Originally Posted by CPDesign View Post
...I have tested continuity,
Did you test for shorts? Soldering high density d-subs is not the easiest thing if you haven't been doing it for a while. Shorts are the most common problem.
What are you connecting with the cable?
Is there a reason you chose that particular cable instead of the usual VGA cable?
Colm is offline
Reply Tweaks and Do-It-Yourself
