Looking for Yamaha replacement cd loading belt - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-07-2013, 06:17 PM - Thread Starter
metropole's Avatar
Quoted: 39 Post(s)
It seems that a loading belt for a Yamaha CD changer needs replacement - is to loose.
It is now roughly 63 mm long when folded. roughly 39mm in diameter.
It is a bit loose. So, it should be slightly smaller.
Where can I find parts like this?
metropole is offline
post #2 of 3 Old 03-08-2013, 09:09 AM
DGF
DGF's Avatar
Liked: 39
You didn't state which model you have, but here are a few sites that might provide a lead for you:
http://www.partstore.com/Model/Yamaha+Electronics+Corporation/Yamaha/CDC635.aspx [IIRC this site has a "How to measure a belt" guide - might be useful if you need to buy a generic belt]
https://www.chsinteractive.co.uk/electrical-components/misc/cdcs90-belt-loading-cd-yamaha.htm [UK-based]
http://www.mcmelectronics.com/ [reasonable collection of belt sets]
...and even Sears carry a few for Yamaha models [parts.sears.com]
DGF is offline
post #3 of 3 Old 03-09-2013, 01:02 PM - Thread Starter
metropole's Avatar
Quoted: 39 Post(s)
Thanks. Found the part on partstore. It is a Yamaha CCD-S90.
Reply Tweaks and Do-It-Yourself
