help please pioneer vsx-821 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-10-2013, 01:09 PM - Thread Starter
earron's Avatar
I have a Pioneer VSX-821 along with a dvr from directv and cant seem to get the lips to sync anyone????
It only does it while watching tv not a problem when watching a DVD or blue ray
earron is offline
post #2 of 2 Old 06-10-2013, 02:16 PM
DGF
DGF's Avatar
Liked: 39
Has this ever worked, or has the problem just started? Have you tried different connections (HDMI versus Optical, etc.)? Does it happen on all sources (live TV, recorded programs, OTA, etc.)? Does it happen with all sound processing options on the Pioneer? Have you set all the config options on the Pioneer back to default (so that you know there's nothing funky hidden in there)? What happens if you bypass the Pioneer - does the problem still exist?
It may be that you don't have an actual "problem" as a lot of receivers induce a discernible lag - it just takes time to do all that clever signal processing. You didn't mention which DirecTV receiver you have, but there may be an option to adjust AV sync. I'm not familiar with the Pioneer receiver range, but you could try different settings, like adjusting the seating distance - your model seems pretty well equipped, so there might be a specific setting to address audio/video synchronization.
DGF is offline
Reply Tweaks and Do-It-Yourself
Pioneer Vsx 821 K 5 1 Home Theater Receiver Glossy Black
