24V Trigger? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 28 Old 07-18-2013, 06:13 PM - Thread Starter
JoeMG's Avatar
I have an amp that I want to trigger when my setup turns on. It requires a 24v trigger. Currently, I have a 24V wall wart connected on my receiver's switched outlet that triggers it. However, i'm upgrading to a preamp that doesn't have a switched outlet, but has 3 12v triggers.
What is the easiest way to get this to happen? If i combine 12V triggers it won't = 24v, correct? I was thinking a relay, but it's kind of a hassle to wire everything up. Any other ideas?
JoeMG is offline
post #2 of 28 Old 07-18-2013, 06:35 PM - Thread Starter
JoeMG's Avatar
JoeMG is offline
post #3 of 28 Old 07-18-2013, 08:45 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 911
Or this: http://www.amazon.com/LM2577-Adjustable-Step-up-Converter-Module/dp/B008HMETBE/ref=pd_bxgy_e_img_z
Looks like either would do the trick.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #4 of 28 Old 07-18-2013, 09:58 PM
Colm's Avatar
Liked: 94
Requires, or supports? Most amps that support a 24v trigger will work just fine with 12V.
Colm is offline
post #5 of 28 Old 07-19-2013, 05:58 PM
Gizmologist's Avatar
Liked: 31
You can also ,if you want, use 2- 12 volt wall warts in series to get the 24 volts if necessary but keep mind the DC output rating of the WW is calculated with a load. There is essentially no load provided by a trigger circuit so the output of a WW rated at 12 volts is likely more like 18 which will definitely trigger a 24v input
Gizmologist is offline
post #6 of 28 Old 08-31-2013, 04:41 PM - Thread Starter
JoeMG's Avatar
I ended up using this: http://www.amazon.com/gp/product/B0085T97PW/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
It worked fine at first... but now the DC trigger doesn't seem to work. if i plug it into the other DC trigger it works. I'm wondering if i blew a fuse or damaged the 12v trigger? it's a marrantz av8801... is there a fuse or something for the trigger?
I don't see how this could have damaged the unit... but i'm afraid to use the other trigger incase it damages it.
basically, i need to find a way to provide 24v, 125ma to this amp when the preamp goes on.
JoeMG is offline
post #7 of 28 Old 08-31-2013, 05:58 PM - Thread Starter
JoeMG's Avatar
I think I found a reasonable solution.
I got an AMX PC-1 off ebay... i'll just use a 24v wall wart with that. should do the trick and not risk my other trigger.
JoeMG is offline
post #8 of 28 Old 08-31-2013, 06:31 PM
Colm's Avatar
Liked: 94
Sounds likes it.
Then you don''t know enough to be playing EE. If you have to provide 24V at 125ma from a 12V source, ignoring losses in the covereter that source is going to have to provide at least 250ma. The AV8801 trigger is rated 125ma. There is no such thing as free power. And the inrush current of the converter you used could be much more than that.
...i need to find a way to provide 24v, 125ma to this amp when the preamp goes on.
And just what make and model amp would that be?
Colm is offline
post #9 of 28 Old 08-31-2013, 06:34 PM
Colm's Avatar
Liked: 94
I think I found a reasonable solution..
I don't think so. That device expects to see a contact clousure, not a voltage. Can the AV8801 work that way?
You are getting closer to a solution, though. All that is required is a 12V relay and a 24v wall wart. But you knew that to start with.
Colm is offline
post #10 of 28 Old 08-31-2013, 06:51 PM - Thread Starter
JoeMG's Avatar
Originally Posted by Colm View Post
Sounds likes it.
well, I definitely agree I don't know enough about this, which is why i started this thread.
help me understand... the pre/pro outputs 12v 150ma, even if the current was less than the 125ma expected by the amp, how would that damage the trigger output? I'm not familiar with the term "inrush current". In my experience with this amp, when there's not enough current, it won't turn on, which wasn't the case here.
It's a Crestron cnampx-7x200... the way i've been using it is that I "fake" a cresnet connection (24v, 125ma) with a 24v ac adapter... this worked great for a while, but i recently upgraded to a pre/pro without a switched AC outlet like my receiver had.
when you say it expects a contact closure... again, i'm really unfamiliar with this, how does that differ from a trigger?
Any help you can lend is greatly appreciated.
JoeMG is offline
post #11 of 28 Old 08-31-2013, 07:03 PM - Thread Starter
JoeMG's Avatar
Here are 2 threads that led me to believe the AMX unit is what I needed... please let me know if i'm wrong (which is totally possible):
http://www.htguide.com/forum/showthread.php?32402-12-volt-trigger-outlet
http://www.avsforum.com/t/1454978/are-there-any-simple-switched-power-outlets-that-work-with-a-12v-trigger-for-sub-woofer
JoeMG is offline
post #12 of 28 Old 08-31-2013, 07:08 PM - Thread Starter
JoeMG's Avatar
by contact closure... Do you mean a constant output vs a pulse? I believe the Marantz gives a constant output... I had the amp on for hours yesterday with the 24v step-up from the trigger, if it was a pulse it never would have stayed on.
JoeMG is offline
post #13 of 28 Old 08-31-2013, 10:59 PM
Colm's Avatar
Liked: 94
The AV8801 is capable of safely providing 12V at up to 125(150?) ma. How much current it will actually provide is a function of the resistance in the device it is connected to. The resistance at the amp is sufficient to limit it to a safe value when connected directly. It doesn't turn on because the voltage is insufficient. The amp requires 3W of power (24V x 125ma). When you put the power converter in the between the two devices, it has to draw 3W plus from the AV8801. 3W = 12V x 250ma. IOW it has to draw twice as much current from the AV8801 than it is designed for.
The power converter is a switch mode power supply. There can be a capacitor in the input to it that looks like a dead short to the AV8801 until it charges up.
A contact closure is like a mechanical switch. If you were to connect a light switch across the terminals of the AMX PC-1 and your amp was plugged into it, flipping the switch would turn the amp on and off. This is quite different from supplying 12V across those two terminals. Depending on the design of the PC-1 and how you hook it up, you might get lucky and have it work. or it may not work, or it may destroy another trigger output, or you may destroy the PC-1.
FWIW a Niles AC-3 or a Xantech AC1 will do what you are trying to do with the AMX PC-1.
Colm is offline
post #14 of 28 Old 09-01-2013, 06:12 AM - Thread Starter
JoeMG's Avatar
Thank you for the explanation... Looks like I have a lot to learn about electricity.
JoeMG is offline
post #15 of 28 Old 09-01-2013, 09:11 AM - Thread Starter
JoeMG's Avatar
I had an epiphany last night... I wish I had thought of it from the get-go... I have a Belkin PF60 power conditioner with a 12v trigger... so i wired the marantz to the power conditioner and set 1 bank of outlets to be switched, plugged the 24v ac adapter into the switched bank and now it works perfectly.
Hopefully someone else can learn from my mistake.
As far as the trigger on the marantz goes... does anyone have any idea if there is a fuse i can replace or did i just ****up my brand new preamp?
JoeMG is offline
post #16 of 28 Old 09-01-2013, 12:50 PM
Colm's Avatar
Liked: 94
Cool!
No idea without looking at a schmetic, and I don't have one. In the good old days, fixing it might have been as simple as replacing a 10 cent transistor. Now I suspect it means replacing a surface mounted IC.
You might want to verify that the trigger is dead with a volt meter set to DC.
Colm is offline
post #17 of 28 Old 04-24-2016, 02:59 PM
Liked: 0
JoeMG
How did you wire this up? When I connect the 24V and Ground, I have to manually hit the override button to get it working.
BtwoG is offline
post #18 of 28 Old 04-24-2016, 06:52 PM - Thread Starter
JoeMG's Avatar
Originally Posted by BtwoG View Post
JoeMG
There's a small screw near the override button, I took a tiny piece of plastic and screwed it down so it holds the "bypass" button. Still working great!
JoeMG is offline
post #19 of 28 Old 04-24-2016, 07:06 PM - Thread Starter
JoeMG's Avatar
Here's a pic. I wrapped the ac adapter around a ferrite core, just to ensure there was no added noise (probably completely unnecessary).
Name:	2016-04-24 21.03.11.jpg
JoeMG is offline
post #20 of 28 Old 04-25-2016, 12:37 PM
Quoted: 78 Post(s)
it's outputting DC, where would noise come from?
scruff67 is offline
post #21 of 28 Old 04-25-2016, 01:11 PM - Thread Starter
JoeMG's Avatar
I have no idea... I figured it wouldn't hurt anything and I don't know enough about electricity to determine whether it was needed or not.
JoeMG is offline
post #22 of 28 Old 04-25-2016, 02:40 PM
Quoted: 78 Post(s)
It's just adding weight
scruff67 is offline
post #23 of 28 Old 04-25-2016, 03:56 PM
Liked: 0
Awesome idea. Thanks.
BtwoG is offline
post #24 of 28 Old 04-29-2016, 06:16 PM
Liked: 0
FWIW a 19V Dell laptop charger works to activate the Crestron too. It's just what I had lying around.
BtwoG is offline
post #25 of 28 Old 05-02-2016, 10:47 AM
Quoted: 78 Post(s)
why? it does nothing
scruff67 is offline
post #26 of 28 Old 11-08-2016, 09:12 AM
Hempire's Avatar
JoeMG,
I bought a Crestron CNAMPX 7x200 yesterday. what is the part number for the Phoenix Connector posted (post #19) in you pic? I am looking for a solution to connect the 24V and Ground on my Amplifier.
V/R - Pat
Hempire is offline
post #27 of 28 Old 11-09-2016, 12:31 AM - Thread Starter
JoeMG's Avatar
Originally Posted by Hempire View Post
JoeMG,
V/R - Pat
I don't know the part number... we just had a ton of them floating around at work, so i grabbed one.
JoeMG is offline
post #28 of 28 Old 12-12-2016, 04:49 AM
chankbro's Avatar
Liked: 2
If you are looking for just a trigger(hope you find it already as this is a 3 year old thread), try conencting those 12 v in a serial manner so that the output is 24 volt(I recommend a idolater before connecting the output as trigger). This is the easiest way I do it.
Follow your thoughts.
chankbro is offline
Reply Tweaks and Do-It-Yourself
