Yamaha Receiver RX-V673 is not playing sound from Samsung 6300 smart tv (via arc) - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Lils Roro
post #1 of 11 Old 07-21-2013, 06:14 PM - Thread Starter
mikamae1's Avatar
we bought the samsung 6300 series smart tv. we also bought the yamaha av receiver rx-v673 and klipsch speakers. our receiver will play the blu ray movies and will play the radio, but we cannot get the tv and the receiver to "talk" and play tv sound using an hdmi (arc). please help. we've looked through everything and tried everything. we do not want to use the optical cable because we should be able to use the arc!
mikamae1 is offline
post #2 of 11 Old 07-21-2013, 06:45 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
Without looking at your manuals, but having gone thru this, first make sure you're using the specific hdmi port (believe number 2) on your tv. Then enable the HDMI-CEC control (in both your tv and avr); each brand calls HDMI-CEC some branded name like Samsung with Anynet, don't know what Yamaha calls theirs.
lovinthehd is offline
post #3 of 11 Old 07-21-2013, 07:35 PM - Thread Starter
mikamae1's Avatar
thank you....we have it in the correct port hdmi 2 (arc).....i think that's where we're having problems----enabling the hdmi cec control....we did enable the anynet on our samsung......and to no avail....
mikamae1 is offline
post #4 of 11 Old 07-21-2013, 07:42 PM
lovinthehd's Avatar
Liked: 4775
So what about on your avr? I googled it and looks like you have something simply called HDMI Control and possibly a separate yes/no designation for ARC. Did you RTM for the avr? cool.gif
post #5 of 11 Old 02-08-2014, 09:06 AM
FourWideJK's Avatar
Did you get this to work ?
I have found that it works with one glitch. I have Bell Box connected to hdmi 1 on receiver, receiver out to hdmi 2 on tv.
When I turn the tv on it turns on the receiver, and put on hdmi 1, a few seconds later it switches to AV4 . If I click select on tv remote to enlarge the tv screen the receiver stays on AV4, which doesn't have any audio. If I go to smart hub and open youtube the audio works on AV4. Then if I go back to tv on smart hub and click on it the audio switches back to HDMI 1 and I have audio.
I can't figure out how to make it switch to hdmi1 without opening one of the apps in smart hub before going to the TV
FourWideJK is offline
post #6 of 11 Old 03-17-2014, 03:20 PM
Rilen's Avatar
I have the same problem. I just bought a Samsung 6300 LED and have a RX-V573. I have new high speed HDMI cables and have it correctly connected using ARC. It works when I watch stuff via Netflix directly from the TV so i know the sound travels from the TV as the source back into the receiver.
Every time I turn on the TV it starts off on the HDMI setting then switches to an AV setting for sound input after about three seconds.  If I switch back to HDMI as the input it stays there and works fine.  Help!
Rilen is offline
post #7 of 11 Old 03-17-2014, 04:15 PM
lovinthehd's Avatar
Liked: 4775
Welcome to the world of HDMI-CEC of different brands fighting for control! Precisely why I gave up on ARC (Samsung tv, Onkyo avr and when using a universal remote the "tv" input would always be selected on the avr even when programmed for the sat/cable input when powering up, very annoying). Besides, with my tv set ARC is limited to two channel, except for OTA content which I don't have any use for. I just turned off HDMI-CEC in both units and use the AVR for all input with only a video output to the tv, I don't use the tv's audio for anything and if I did I'd just hook up an optical cable to the avr for that. Certainly they could do better by agreeing on same protocols but HDMI-CEC hasn't been implemented that way among various brands. Probably the fault of some genius in marketing....
post #8 of 11 Old 06-08-2014, 08:28 AM
masaccio's Avatar
After quite a bit of faff, here's how I did this with my 6500 series TV:
1. Connect an HDMI cable between the receiver's HDMI Out and the HDMI input on the TV labelled with ARC (for me it was HDMI2)
2. Switch the TV to HDMI2 (or whichever one you chose for ARC)
3. Select On Screen on the receiver remote, choose Setup, HDMI and then HDMI Control. Make sure it's "On".
4. Switch the receiver input to AV4
5. Switch the TV back to TV and go to System → Anynet+ (HDMI-CEC) and enable it
6. Turn the receiver off, then the TV off
7. Turn the receiver on, then the TV on
For me it just worked at this point. The trick for me was that the receiver needs to be using AV4 as its input. Clear as mud, eh?
masaccio is offline
post #9 of 11 Old 03-06-2015, 04:29 PM
zxvfrr41's Avatar
Originally Posted by masaccio View Post
<div class="quote-container" data-huddler-embed="/t/1482624/yamaha-receiver-rx-v673-is-not-playing-sound-from-samsung-6300-smart-tv-via-arc#post_23550219" data-huddler-embed-placeholder="false">Quote:
<div class="quote-block">Originally Posted by <strong>mikamae1</strong> <a href="/t/1482624/yamaha-receiver-rx-v673-is-not-playing-sound-from-samsung-6300-smart-tv-via-arc#post_23550219"><img alt="View Post" src="/img/forum/go_quote.gif" style=""></a><br><br>
we bought the samsung 6300 series smart tv. we also bought the yamaha av receiver rx-v673 and klipsch speakers. our receiver will play the blu ray movies and will play the radio, but we cannot get the tv and the receiver to "talk" and play tv sound using an hdmi (arc). please help. we've looked through everything and tried everything. we do not want to use the optical cable because we should be able to use the arc!</div>
</div>
<p>After quite a bit of faff, here's how I did this with my 6500 series TV:</p>
<p> </p>
<p>1. Connect an HDMI cable between the receiver's HDMI Out and the HDMI input on the TV labelled with ARC (for me it was HDMI2)</p>
<p>2. Switch the TV to HDMI2 (or whichever one you chose for ARC)</p>
<p>3. Select On Screen on the receiver remote, choose Setup, HDMI and then HDMI Control. Make sure it's "On".</p>
<p>4. Switch the receiver input to AV4</p>
<p>5. Switch the TV back to TV and go to System → Anynet+ (HDMI-CEC) and enable it</p>
<p>6. Turn the receiver off, then the TV off</p>
<p>7. Turn the receiver on, then the TV on</p>
<p> </p>
<p>For me it just worked at this point. The trick for me was that the receiver needs to be using AV4 as its input. Clear as mud, eh?</p>
I have the exact same setup as you and ARC worked fine. One night I plugged in an HDMI cable from my computer to HDMI1 on the TV to watch NHL Gamecenter and I didn't get any sound. I then went to Netflix on the smart TV and no sound either. It was working fine for at least two years and then one night I can't get any sound. Nothing changed in my setup.
HDMI cable from Samsung PC63C8000 HDMI2(Arc) to Yamaha RX-V673 HDMI out.
TV HDMI-CEC is enabled.
ARC is On on the receiver.
TV output on the receiver is set to AV4. I tried changing it to different AV's as the TV output but still nothing.
I get video but no sound. I replaced the HDMI cable but it still didn't work. For connecting my computer, I tried a different HDMI port on the TV and still no sound.
I'm out of ideas. If the ARC port on the TV went bad, I don't think I'd even get video but video is fine.
zxvfrr41 is offline
post #10 of 11 Old 03-06-2015, 06:35 PM
Quoted: 236 Post(s)
Liked: 81
Since ARC can't pass through DTS Master or Dolby TrueHD audio, I would think the only advantage it has over optical digital is one less cable.
lovinthehd likes this.
Lils Roro is offline
post #11 of 11 Old 06-15-2015, 01:51 PM
Liked: 0
You just have been my god!thanks a lot
Apostolis Dm is offline
Reply Tweaks and Do-It-Yourself
Yamaha Rx V673 Receiver
