butterworth filter design - AVS Forum | Home Theater Discussions And Reviews
Old 07-31-2013, 03:30 PM - Thread Starter
talha's Avatar
hello!
i have two signal at input(ac+dc) but i want only dc.and wanted to remove ac.so for that purpose i am using butterworth filter
and its cutoff frequency=20hz,
now kindly tell me
1:which butterworth filter amp i use low or high pass?
2:while input have both ac and dc signal but i want output of that filter is only dc(1.5volts).
3:after getting this dc of 1.5v we have to amplify to 12volts.so which amplifier i can use please send the circuit 4:plz send me butterworth filter(specifications) design and circuit diagrams.
plzzzzz i need this argent...
you can also send the solution to my problem via email
email:tmeleven@live.com
talha is offline
Old 07-31-2013, 08:51 PM
Colm's Avatar
Liked: 94
Is this for an electronics class?
Colm is offline
Old 08-01-2013, 01:48 AM - Thread Starter
talha's Avatar
yes...please tell me the solution
talha is offline
Old 08-01-2013, 10:52 AM
Colm's Avatar
Liked: 94
No, you need to do the research and figure it out for yourself. If I told you, you would not learn anything.
talha likes this.
Colm is offline
Old 08-02-2013, 12:12 PM - Thread Starter
talha's Avatar
I am very busy and not enough time for research...i know that's is not good way for learning but please help me this time...i need this argent
talha is offline
Old 08-02-2013, 06:24 PM
SAM64's Avatar
Liked: 78
This is a really simple problem. If you don't have a clue how to solve it, why bother taking the course? Out a little thought into it, it's not hard.
SAM64 is offline
Old 08-03-2013, 05:51 AM - Thread Starter
talha's Avatar
dear
i search the answer and get it but i need to confirm it from you...because i want perfect ans because i made device from this..
so give me answer this time .......plzzzzzzzzzzzzzzzzzzzzzzzzzz
talha is offline
Old 08-03-2013, 10:20 AM
Colm's Avatar
Liked: 94
So, what solution did you come up with?
Colm is offline
Old 08-04-2013, 02:10 AM - Thread Starter
talha's Avatar
i am show my design check this tell is this correct Design.pdf 865k .pdf file
also tell your email address.
talha is offline
