Long range video and audio transmission ~ 20,000 feet - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-08-2013, 10:43 AM - Thread Starter
Jackster22's Avatar
Hi all.
Anyone know of a way to send video and audio signals wireless with a range of about 20km?
We would only need SD video coming from a camera. And it would have to be quite light weight and run off a 12v system for the transmission equipment.
This is more of a hobby thing so can't spend a ton on it. So looking to go real DIY on this one to bring the cost down, would even be prepared to build circuit boards.
Jack,
Jackster22 is offline
post #2 of 5 Old 08-08-2013, 02:52 PM
Colm's Avatar
Liked: 94
AFAIK in the USA what you want to do requires a license of one sort or another.
There are amateur radio enthusiasts that do it. Here is a link that will give you an idea of what is involved.
Colm is offline
post #3 of 5 Old 08-08-2013, 05:34 PM - Thread Starter
Jackster22's Avatar
Thanks for that link.
I am in the UK and the transmission would only be a few hours.
We don't use analogue anymore so probably not going to bother getting permission for the band.
Thanks again!
post #4 of 5 Old 08-08-2013, 07:31 PM
DtommyD's Avatar
If its" line of site" there's tons of info online about long range wifi. It can be as simple as using 2 old Dish Network dishes pointing at each other. You could have a slingbox on one end of a really long wifi network.
Although you mentioned 12v so I'm thinking there isn't any power right? And under $100? Maybe I don't have any ideas after all.
What about a cell phone with unlimited data? Skype?
A neighbor with wifi?
If your buying a new projector, buy more lumens than you will use. Running it in "Eco Mode" makes your bulb last 20-40% longer and reduces noise and heat.
DtommyD is offline
post #5 of 5 Old 08-09-2013, 04:07 PM
Speedskater's Avatar
Quoted: 20 Post(s)
Run the camera output into an old VHS recorder, then the channel 2,3 or 4 output into a big VHF antenna, at the far end another big VHF antenna.
Sure it's not technically legal, but just who would you interfere with?
This should work at 20 000 feet ( 4 miles) but not 20 kilometers (12 miles).
Kevin
Speedskater is offline
Reply Tweaks and Do-It-Yourself
