Need help finding fuse - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-11-2013, 08:16 AM - Thread Starter
ilpostini2's Avatar
Quoted: 41 Post(s)
I am trying to locate a t6 3ah/250v pigtail fuse to repair one that blew to to a lightning strike.
I can't locate one locally in the Boston, Ma area.
Does anybody know where I can buy one of these?
ilpostini2 is offline
post #2 of 5 Old 09-11-2013, 08:27 AM
walterappleby's Avatar
Quoted: 25 Post(s)
Liked: 77
http://www.amazon.com/T6-3AH250V-T6-3H250V-cartridge-6-3A-SLOW-blow/dp/B008R8S1JO
I had luck at Radio Shack in the past for fuses like this. They used to have a divided drawer with a bunch of different sizes/specs.
Good Luck!
walterappleby is offline
post #3 of 5 Old 09-11-2013, 08:35 AM - Thread Starter
ilpostini2's Avatar
Quoted: 41 Post(s)
Thanks, but these don't have the pigtails.
I need to solder them onto a board.
post #4 of 5 Old 09-11-2013, 09:45 AM
Quoted: 25 Post(s)
Liked: 77
Ah. Sorry I missed the pigtail...
Try Mouser Electronics... hopefully you can find what you need there. I've used them for a few things in the past. Good to work with from what I remember, but it's been a few years.
http://www.mouser.com/Circuit-Protection/Fuses/Cartridge-Fuses/_/N-ba8h0?FS=True
post #5 of 5 Old 09-12-2013, 01:37 PM
gearheadslife's Avatar
I just got fuses I needed for my B&K from mouser electronics
1000 north main street Mansfield tx 76063
contact Matt Bell 817-804-3800
shipping was like 5 bucks iirc,
and they where over packed, plastic ziplock type bag, wrapped in bubble wrap and then in a box. overkill if you ask me.
City electrical supply in Brockton has a ton of different fuses, but just didn't have what I needed as mine called for a dual element slow burn/blow fuse and the only one they had that crossed to it, was a single element slow blow might try giving them a call as they are only 20 minutes from you
you try ralph pill in Dorchester or yale electric in Dorchester right off 128
gearheadslife is offline
Reply Tweaks and Do-It-Yourself
