Sencore VS. Progressive Labs VS. Milori - Page 3 - AVS Forum | Home Theater Discussions And Reviews
Closed Thread
post #61 of 65 Old 10-09-2002, 04:53 PM
Mark Hunter's Avatar
Yes. The Avia/VE/external test image measurement calculation issue has been resolved as of version 2.01.
Mark Hunter
Technical Director, Home Theater Products
Datacolor, Inc.
Mark Hunter is offline
post #62 of 65 Old 10-13-2002, 07:02 PM
Brett's Avatar
Hi Mark,
Any news of a "joe six-pack" priced sensor for screen readings? I'd be using it with at high gain Torus which might well throw off any color settings made directly from the guns...
TIA
Brett
Brett is offline
post #63 of 65 Old 10-13-2002, 07:59 PM
Brett - Nice to hear from you again!
Drop me an e-mail. markh at milori dot com
Mark Hunter
Datacolor, Inc.
post #64 of 65 Old 10-14-2002, 02:21 PM
jdmcdonald's Avatar
If you are looking for a sensor, for about $2000, less if OEM'd into
something else, that is essentially perfect, consider the Ocean
Optics PC2000 or similar things from them (The PC2000 has the
present disadvantage that it requires a PC with an ISA slot).
This is a full visible spectrophotometer with a fiber optics probe. It
has enough resolution to be totally accurate. Only problem is that it
needs a calibration lamp to become "absolute". Once calibrated with
a lamp of known color temperarture, it can, of course, calculate colors and color temperature with any spectral distribution whatsoever.
One could have .... maybe they sell ... software that plots the
color on a CIE diagram, and gives the color nearest color temperature
and how far the green is from a "real" temperature.
I've used lots of these and they are very good and very reliable.
The idea of spending over $3000 for the sensor part of anything
used to adjust TV sets totally boggles the mind. It is simply not needed.
Doug McDonald
jdmcdonald is offline
post #65 of 65 Old 10-14-2002, 04:53 PM
kevin gilmore's Avatar
The oceanoptics usb2000 is an absolutely fabulous device. Plugs
into a usb hole and is totally self contained. Among the most sensitive
of all sensors out there. Requires a glass fiber probe that breaks easy.
For pointing at the screen it would also require a light spreader.
Minimum oem cost with fiber is about $2600. Mercury calibration lamp
an additional $600. We have the complete SDK for this device and
i have a couple at work. We would be happy to support this device
if there was enough interest in it.
The sony ixl521 sensor that is inside the unit has been discontinued
and the replacement sensor will not be anywhere near as sensitive.
kevin gilmore is offline
Closed Thread Tweaks and Do-It-Yourself
