Audio Not on for netflix on smart tv 51 inch samsung with digital to analog convertor - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-16-2014, 12:28 PM - Thread Starter
kinyi2007's Avatar
Hi,
i have my Digital to analog convertor connected to the TV using optical digital cable, but when on netflix the sound does not come on. the only reason i have it is to use headphone jack, to keep the peace.i have the headphone jack on the receiver, but only one side has sound coming on. How do i get the sound when i am on metflic on my smart tv.
The receiver has analog cable provision which do not seem to work with this tv and a coaxial cable connector that I have not tried yet. I suspect netflix would still not have sound. Does anyone know where on the tv i can adjust some settings for it to give sound on the reciever.
kinyi2007 is offline
post #2 of 3 Old 06-04-2014, 07:10 PM
Krispy Kritter's Avatar
Quoted: 53 Post(s)
How is everything connected (ports, cable types, etc.) and what devices (brand and model #'s) are being used.
Krispy Kritter is offline
post #3 of 3 Old 06-05-2014, 09:55 AM
jautor's Avatar
Quoted: 1218 Post(s)
Liked: 782
Does your digtial-to-analog (DAC) converter support Dolby Digital or just PCM? If you bought a very inexpensive model (say <$50), it likely only supports PCM. You may be able to configure the TV / apps to output stereo (PCM) only instead of DD5.1... Which for headphones pay be fine.
Jeff
jautor is offline
Reply Tweaks and Do-It-Yourself
