Switch on computer with RS232 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By jautor
post #1 of 8 Old 06-16-2014, 02:08 AM - Thread Starter
Liked: 0
Question Switch on computer with RS232
Hey guys,
I'm new here, so if I am in the wrong place, let me know.
Is their a way to switch on a home theater PC with an rs232 command. I have a calypso cb-1000 as a controller and a Acer Travelmate 6460, which is great, but I would like the controller to turn the machine on. I am easy to do DIY.
Any suggeststions are welcome
Thank you in advance, BDMAN32
bdman32 is offline
post #2 of 8 Old 06-16-2014, 01:08 PM
Liked: 0
Although I never done it, I am assuming that would be relatively easy to write using C# or Java implementing one of the PELCO protocols...
I might be wrong, but protocol is there; you just need to send a recognizable set or bits using an interface. Does not sound complicated
rayzak is offline
post #3 of 8 Old 06-16-2014, 03:36 PM
jautor's Avatar
Quoted: 1319 Post(s)
Liked: 844
Except that any PC / Laptop in any "standby" mode will not respond to an RS232 command. The only port active would be the Ethernet NIC, which you could use to bring the unit out of standby using the Wake-on-LAN "magic packet". I believe folks have done that using iRule even...
Using an external AC power switch will only work if the computer supports a 'Power Restore State' so that the machine will power on (not remain in standby) when AC power is applied.
SMHarman likes this.
NOTE: I am fixing photo links in my theater thread - if you find dead photo links elsewhere, please PM me and I will fix it.
jautor is online now
post #4 of 8 Old 06-29-2014, 10:32 PM
EricN's Avatar
Quoted: 154 Post(s)
Liked: 240
It's called Wake-on-Ring. Using a COM port to wake a pc has been around for a long time and you can still find motherboards that support it. Putting 5v on pin 9 (Ring Indicator) is all it takes.
EricN is offline
post #5 of 8 Old 06-29-2014, 11:02 PM
jautor's Avatar
Liked: 844
I suspect any motherboard suitable for use as a HTPC probably lacks actual serial (COM) ports, so you'd be looking for USB support through an RS232 adapter, and I'd be surprised if there was support for it through all that... But if one exists, that certainly would be an easy path.
post #6 of 8 Old 06-30-2014, 07:19 AM
EricN's Avatar
Quoted: 154 Post(s)
Liked: 240
Many motherboards still have an internal COM header. You make them external with one of these:
http://www.amazon.com/StarTech-com-S.../dp/B001Y1F0HW
EricN is offline
post #7 of 8 Old 07-01-2014, 03:54 PM - Thread Starter
Liked: 0
The machine does have an internal COM Port, so that is fiine, the OS is ubuntu so i am not sure how that would go down
And it is an Acer Travelmate 6460 Laptop
bdman32 is offline
post #8 of 8 Old 07-05-2014, 01:19 PM
jautor's Avatar
Liked: 844
D'oh! It didn't even occur to me that the headers would still exist and be populated... That would be a good solution!
Reply Tweaks and Do-It-Yourself
