Using RCA instead of Banana Plugs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 06-16-2014, 12:58 PM - Thread Starter
Liked: 0
Question Using RCA instead of Banana Plugs
I am building a built-in 5.1 surround and I purchased a recessed panel that fits Power outlet and 1 more plate insert of my choice. I want to find a more compact banana plug alternative
I am thinking to buy ONE 6 RCA wall plate and use 5 RCA's to connect to my speakers and 1 RCA that will run to my sub(+1 Sub wall plate).
I don't really want to go with 2 plates of Bananas (5 speakers- 10 connectors! + sub) - it is larger than I want and I would have to replace my recessed panel.
This is the panel example: http://www.amazon.com/HDMI-Component...qid=1402948566
I am not a sound pro and decided to check if there are any complications with RCA connectors (that bananas don't have)
IMHO connector is a connector and it should not make any difference (besides the look and maybe audio 'standards')
please advise.
rayzak is offline
post #2 of 8 Old 06-16-2014, 02:36 PM
FlyingDiver's Avatar
Quoted: 208 Post(s)
Liked: 60
Are you planning on using normal speaker cable attached to these RCA plugs, or the single conductor + shield normally using with RCA plugs?
I don't think you can connect speaker wire (14 or 16 ga) to an RCA plug. It's designed for much smaller wire sizes.
FlyingDiver is offline
post #3 of 8 Old 06-16-2014, 11:09 PM - Thread Starter
Liked: 0
rayzak is offline
post #4 of 8 Old 06-17-2014, 02:39 AM
Quoted: 208 Post(s)
Liked: 60
That's designed for UTP (Cat5e/Cat6) cable. You won't be able to get a decent gauge speaker wire into them.
post #5 of 8 Old 06-17-2014, 04:51 AM
dharel's Avatar
Liked: 33
please advise.
How do you intend to use 5 RCA connectors for your speakers, when you need both a + and - for each speaker? Your idea will not work. You need a panel like this for 5 speakers:
http://www.amazon.com/Quality-Banana.../dp/B001HRN2YQ
For 5.1 it's like this:
http://www.monoprice.com/Product?c_i...seq=1&format=2
I know these aren't what you are looking for, but I don't see a way of using the panel you posted.
dharel is offline
post #6 of 8 Old 06-17-2014, 08:11 AM
jautor's Avatar
Quoted: 1331 Post(s)
Liked: 852
Use a scoop plate instead for all your connections. Since it's recessed and behind equipment anyway, you won't see it, and you'll have better connections - especially on HDMI.
http://www.amazon.com/Arlington-CE1-...ds=scoop+plate
NOTE: If you find dead photo links in any of my posts, please PM me and I will fix it.
jautor is offline
post #7 of 8 Old 06-17-2014, 07:15 PM
olyteddy's Avatar
Quoted: 536 Post(s)
Liked: 941
1/4" Tip Ring plugs are often used for speakers. They have plenty of room to solder.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #8 of 8 Old 07-30-2014, 09:31 PM
cshepard's Avatar
Quoted: 21 Post(s)
Liked: 38
Sure you can. We soldered RCA connectors onto 16/2 for subwoofers all the time back in the day. I use RG-59 now though.
cshepard is offline
Reply Tweaks and Do-It-Yourself
