RS232 From Win7 to PT-AE8000U - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-22-2014, 07:04 AM - Thread Starter
webink's Avatar
I'm trying to write a batch file or script that will switch my aspect ratios from my windows 7 PC. I'm connected via USB to Serial Cable to the projector. I've searched a lot but haven't found anything that works for me. I can't even get a basic on or off command to work. Has anyone ever done this?
webink is offline
post #2 of 6 Old 07-22-2014, 10:01 AM - Thread Starter
webink's Avatar
Ok, so here's what I learned today for anyone wanting to try this.
Got a gigaware USB to serial cable. Plugged it in and it was assigned COM1
In hyper terminal, open a connection to your com port
To start a command press CTRL+B
Type your command in all caps
Press CTRL+C to end the command
So here's what it looks like to load lens memory 6 on the 8000
Ctrl+B VXX:LMLI0=+00005 CTRL+C
Here's power off
Ctrl+B POF Ctrl+C
as a note, there are no spaces before, within or after the command.
So does anyone have any idea how to turn this into a batch file or a script I could run?
webink is offline
post #3 of 6 Old 07-22-2014, 01:51 PM
Michael Sargent's Avatar
Quoted: 199 Post(s)
Liked: 175
Put the commands into text files (copy con: filename.txt) and then create batch files that copy the text files to com1: (copy filename.txt com1
Mike
Michael Sargent is offline
post #4 of 6 Old 07-22-2014, 03:01 PM - Thread Starter
webink's Avatar
Do you know how I would send the CTRL+B and C? Those are the start and end commands.
webink is offline
post #5 of 6 Old 07-23-2014, 07:06 AM
Quoted: 199 Post(s)
Liked: 175
I'm not sure how to do it with regular batch files, but it's pretty easy using PowerShell.
PS C:\Windows\System32\WindowsPowerShell\v1.0> $msg = [char]2 + "text" + [char]3
☻text♥
post #6 of 6 Old 08-12-2014, 01:53 PM
Liked: 0
Lightbulb Solution PT-AE8000U RS232 projector automation control
To control peripheral like a projector I usually use Bill Redirect software from www.Billproduction.com company
Solution to control your projector PT-AE8000U:
Manual of the protocol (commands) of your projector: www.audiogeneral.com/Panasonic/ptae8000u.pdf
Step by step solution:
- First download and install Bill Redirect Software: http://www.billproduction.com/Bill_COMtoKB.ZIP
- Disable all section except: Serial Port and Virtual Keyboard
- In section Serial Port, set the Switch to: On
- In serial Port Configuration, set:
  • In field "Serial Port Number" enter the port number where your projector is connected.
  • Bauds: 9600
  • Parity: None
  • Databit: 8
  • Stopbit: 1
- Click on: Virtual Keyboard Configuration
- After click on: Add
* At this point a button appear ... it's your action button ... used latter to control your Projector !
- Enter the command you want to do in the field "String to send ... is push" example to set the input to HDMI 1 use this command:
{ASCII:2}IIS:HD1{ASCII:3}
*** Another example ... the command to "Picture mode switch" is: {ASCII:2}OVM{ASCII:3}
*We have found each command in the manual of your projector
To test your button click on: Run
- Click on the virtual button created to test the command !
- You can create several buttons to control what you want ...
For more information about the possibility, use the manual of the product: http://www.billproduction.com/Bill_Redirect_Manual.pdf
This solution can work's with any peripheral !
Paul
bliebb is offline
Reply Tweaks and Do-It-Yourself
