Upscaling resolution without buying a special device - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 07-31-2014, 12:47 PM - Thread Starter
Jay Filippone's Avatar
Hi:
I stumbled on this last week. I guess necessity is the mother of invention.
I have some VHS tapes that I want to transfer to DVD and Blu-ray. I got a used Super/S-VHS player for $25. I connected it to my DVD recorder (DVDR). I took the component output of the DVDR and connected it to my HD capture card (Avery Media HD USB). By daisy-chaining these devices, I was able to improve the video quality significantly. I ordered a used Monster S-Video cable to see if I could further improve the resolution.
Cheers.
Jay Filippone is offline
post #2 of 11 Old 07-31-2014, 01:52 PM
SAM64's Avatar
Liked: 78
I hate to break it to you, but you haven't upscaled or improved resolution at all.
SAM64 is offline
post #3 of 11 Old 07-31-2014, 03:21 PM - Thread Starter
It certainly looks much better than if plugged the S-VHS directly into my HD capture card. I'm sticking to my guns, Kemosabe.
post #4 of 11 Old 07-31-2014, 04:02 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
You are correct. You can't improve resolution but some DVD recorders perform very well as Time Base Correctors and noise reducers so can significantly improve VHS signals passed through them.
http://forum.videohelp.com/threads/3...hat-do-you-use
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #5 of 11 Old 07-31-2014, 04:19 PM - Thread Starter
Thanks for your feedback, olyteddy.
Do you think this device could make an additional improvement?
http://www.ambery.com/bnccostocovi.html
post #6 of 11 Old 07-31-2014, 09:58 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
No.
olyteddy is offline
post #7 of 11 Old 08-14-2014, 01:08 PM - Thread Starter
Which pic looks better to you? Thanks in advance for opining.
Jay
Name:	setzer comparison2.jpg
post #8 of 11 Old 08-17-2014, 07:53 PM
fcwilt's Avatar
Quoted: 43 Post(s)
Liked: 26
I don't like either one.
Regards, Frederick C. Wilt
fcwilt is offline
post #9 of 11 Old 08-19-2014, 02:05 AM
Liked: 0
Jay
Second one looks a bit sharper than the former..
waltermoss123 is offline
post #10 of 11 Old 08-19-2014, 03:07 PM - Thread Starter
Thanks, Walter.
post #11 of 11 Old 08-26-2014, 10:19 AM
drewman21's Avatar
Jay,
Not sure if you are still checking this thread but the second one looks better than the first.
As for improving the picture quality of your captured video you would be better off having a clean capture of the native output of the device and doing software processing to try clean up the image. I say try because there is only so much you can do with older video and conversions. Not sure what you are using for capture,edit,and burning software but some programs allow for de-noising video, de-interlacing, and general color fixes. This does take time for the video to process but you can achieve "cleaner" video than you started out with.
drewman21 is offline
Reply Tweaks and Do-It-Yourself
