JLDP and Ciar SU15/M1 Recliner Control Box Repair - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 03-01-2017, 06:30 PM - Thread Starter
hdtvluvr's Avatar
Quoted: 37 Post(s)
Liked: 32
Well, I searched for a replacement Control Box for my Berkline chairs. I found a "double" CIAR version at about $190 each. Then I found the JLDP here:
http://www.recliner-handles.com/repl...ift-chair.html
$90 each. I did order from them before I tried to fix mine. The one I received was dated 08/07 so maybe they are new old stock. Not sure.
Well, then I decided to see if I could fix mine. Found a replacement transformer for < $9 (https://www.zoro.com/white-rodgers-c...24/?q=90-T40F3). It is designed for 120, 208 and 240 volts. It has 4 input wires but only need 2. I could have gotten a 120V version only but it was $13. I can cut 2 wires and save $4. So a little work and I have a repaired one that I put on another chair that was also going bad. Will see if the issue is resolved.
See attached pdf for instructions.
Hope it helps someone.
hdtvluvr is offline
Reply Tweaks and Do-It-Yourself
