Any Mech engineers out there, or the like - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-19-2017, 08:17 AM - Thread Starter
kgveteran's Avatar
Quoted: 487 Post(s)
Liked: 178
I have a door I built to separate my videoroom from the rest of the house. Part of the door has a magnetic door seal like a fridg, the other part needs a expandable air seal that can inflate with as little as 5-10lbs of pressure.
the whole thing and air tubing will be covered up by the OC703 board and mounted to the doors face...
I designed a device, which I have no idea what to call, but it will do what I want. The gravity of the rod in the PVC tube along with the seals and some silicone lubricant, should give me the amount of pressure, but I have no knowledge how to ever approx. design the rod as to weight, what size rod or how many pounds must the weight be. Could it be a direct correlation of 5lbs of steel equals 5lbs of pressure ???
Help
kgveteran is offline
post #2 of 9 Old 03-19-2017, 04:16 PM
smoothtlk's Avatar
Quoted: 82 Post(s)
Liked: 45
So, you are building an "air lock"?
I believe the pressure will be the weight of the piston (steel) minus the friction of the seals.
Calculate the Sq in of the piston end. Lbs / sq inch will be the result.
Area = Pi * R^2
so if the piston in one inch in diameter:
.79=Pi*.5^2
If the weight was 10lbs:
10lbs / .79 sq inch or 8lbs / sq inch
One inch round steel bar is 2.67 lbs / inch
So, you will need a bar 3 3/4 inch long x 1 inch
Or something like that
smoothtlk is offline
post #3 of 9 Old 03-19-2017, 04:51 PM - Thread Starter
kgveteran's Avatar
Quoted: 487 Post(s)
Liked: 178
Area = Pi * R^2
.79=Pi*.5^2
Wow, Ty. Whats an airlock used for, setups like this. I had imagined this thing being huge due to my lack in math skills
If I make it bigger, just a little overkill can I add a pressure gauge, just for a cool factor, and if that's easy, can I limit the pressure easily if 10psi is too much, like a shut off valve, or a limiting valve.....
post #4 of 9 Old 03-19-2017, 06:25 PM
smoothtlk's Avatar
Quoted: 82 Post(s)
Liked: 45
Don't forget I didn't put any losses in for Oring friction...that's a matter of your precision, the type of O'ring and lubrication.
post #5 of 9 Old 03-25-2017, 06:16 AM
Liked: 9
Keep in mind that pounds is a total force and psi is force/area. Do you need it to provide a total of 10lbs total force or does it need to resist 10psi over the area of the panel? This works for the former but will require a bigger system for the latter unless your movable panel is only 1 square inch.
Kigmatzomat is offline
post #6 of 9 Old 04-06-2017, 07:53 PM
Bigus's Avatar
Quoted: 412 Post(s)
Liked: 386
How long does this system need to main pressure? I have concerns about low level leaks around o ring seals inside typical readily available pipes and tubes. Especially if you want a reasonable amount of friction so the weight actually moves in the tube. I can imagine the friction getting out of hand trying to maintain a seal, the rod having to be increased in length to compensate, then the friction becoming a bit inconsistent such that you get a situation where the rod doesn't move... until it does, then pressure spikes up rapidly.
But I'm just concerned. It might turn out OK.
Bigus is offline
post #7 of 9 Old 04-06-2017, 08:36 PM
Bigus's Avatar
Quoted: 412 Post(s)
Liked: 386
Just a suggestion... consider a sealed bladder with a weight resting on top if you have room for that physical arrangement. Rock on a balloon. Easier to maintain seal. If it needs to be tall and thin, could be a slender balloon. Just a thought.
Bigus is offline
post #8 of 9 Old 04-07-2017, 10:45 AM - Thread Starter
kgveteran's Avatar
Quoted: 487 Post(s)
Liked: 178
The seals are about $400 for both. Thats not going to work, i can spend that somewhere else.
I have seen door seals at the bottom of a door that seal when the door is closed, im going to research the design and see if i can apply it to my situation, the magnetic seals should be done next weekend, so i will have a much clearer picture of what my options are.......
I cant seem to get the lighting right to take pics
post #9 of 9 Old 04-07-2017, 11:25 AM
djc11369's Avatar
Quoted: 286 Post(s)
Liked: 161
Close
10lbs / .79 sq inch or 8lbs / sq inch should be 12.7 lbs/in2
A one inch round steel bar is 2.67 lbs/ft or close to it depending on what you use for density. As a double check (density) x (volume) = weight so steel density that I used back in my engineering classes many many years ago is .284 lbs/in^3. So (.284 lbs/in3) x ((.79in2)x12in) = 2.69 lbs or divided by 12 to make units easier to follow is 0.224 lbs/in
So with this corrected info for a the 1" bar to exert 10 psi ignoring frictional losses you would need, F= 10*0.79 which is 7.9 lbs. 7.9 lbs divided 0.224 lbs/in is 35.9in.
This was fun, makes me really miss my Mechanical days.
djc11369 is offline
Reply Tweaks and Do-It-Yourself
