DIY Projector Table - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-08-2017, 06:53 PM - Thread Starter
Quoted: 123 Post(s)
DIY Projector Table
Ok guys. I don't know if this is the right section of the forum but this is the only DIY section I can find. If i should post this somewhere else I apologize and can someone please let me know where i SHOULD take this. I am looking to do a DIY end table that will contain my projector within it in a hidden compartment that will pop up. Think of it like a drawer except the drawer will rise up and out of the table top. I have it all planned out in my head but I cannot find a motorized lift that will cost me less than 2000 dollars. That is DEFINATLEY too much to spend. If i can get some ideas on something else i can do to get it to lift or a different device I would be appreciative. Though not a must, an electronic lift would be preferable.
Thanks i advance.
Leon1972 is offline
post #2 of 3 Old 05-13-2017, 08:05 PM
smoothtlk's Avatar
Quoted: 82 Post(s)
Liked: 45
Look at linear actuators...a lot of Tuners use these.
https://www.ebay.com/p/?iid=191299721987&&&chn=ps
You could fabricate some brackets to move the table up to correct position, and use the linear actuator to do the work.
smoothtlk is offline
post #3 of 3 Old 05-13-2017, 08:20 PM - Thread Starter
Quoted: 123 Post(s)
Thanks! I'll look into it. I have basic electrical work knowledge from work but it looks simple enough!
Leon1972 is offline
Reply Tweaks and Do-It-Yourself
