Maximum VGA cable length? Cat5 for video? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 08-08-2003, 11:29 PM - Thread Starter
MentatYP's Avatar
I'm setting up a projector that will require a looooong VGA cable. I haven't measured how long exactly, but I know it will be at least 50 feet.
Does anybody know the maximum run length for VGA cable? Is there a better option to carry a signal from a laptop's VGA-out to a projector's DVI-in?
Second issue: I also need to run cable for the RCA video-in on the projector, same cable length as the VGA cable above. I've heard of RCA-to-Cat5 converters that allow longer runs of video signal in this manner. Are there any significant disadvantages to this method?
Thanks for the help.
MentatYP is offline
post #2 of 10 Old 08-12-2003, 08:44 AM - Thread Starter
MentatYP's Avatar
Anybody? Should I post this in a different area?
MentatYP is offline
post #3 of 10 Old 08-12-2003, 05:30 PM
NizZ8's Avatar
Liked: 25
I'm using a 50' VGA cable from my PC to my Projector with no problems.. i didn't make it myself though, i purchased it off ebay.. pM me if you want more info on it. it cost me a total of 30$ including shipping and all..
The VGA-> Cat 5 soution is pretty expensive from what i've heard.. unless you tlaking about just carrying Component signal over cat 5, i've heard that max with that is around 25' or so..
NizZ8 is offline
post #4 of 10 Old 08-13-2003, 09:55 AM - Thread Starter
MentatYP's Avatar
Ok, so we know that 50' will work okay. Does anybody else have any experience running longer lengths or know for sure what the theoretical max is before you need a signal repeater?
MentatYP is offline
post #5 of 10 Old 08-14-2003, 01:54 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
I think good quality shielded VGA is actually going to be better than Cat 5. It is designed for high bandwidth analog signal. I have heard of VGA working at up to 100 feet, but I have not done this. It will depend on 1) Source 2) cable quality and 3) projector. I would not try this at 1600x1200 resolution at 100 Hz refresh, but 1024 x 768 at 60 Hz, it should be OK - but then I only run 30 feet.
lespurgeon is offline
post #6 of 10 Old 08-14-2003, 05:13 PM
Mikedd's Avatar
Hi,
Good VGA cables can and are run at 1000'. You would not use a signal repeater but a video line driver such as an Extron 202 xi or equivalent. Make sure you get yourself a very good quality cable with proper terminations to avoid ringing or loss. Usually you can do 50' to 75' with no noticable loss on a good cable. Drop by the CRT forum and the guys there can hook you up with some cables I'm sure. I have never used CAT 5 but Ihave done/seen many high end installs and I have yet to see this done.
Mike
Mikedd is offline
post #7 of 10 Old 08-14-2003, 10:54 PM
shokunin's Avatar
There are number of Extran VGA cables of good quality on ebay. There are other online vendors such as markertek, have inc, and avcable.com that sell good quality VGA cables using Canare, Belden, Gepco cables. 50' of composite RCA cables can easily be ordered from these same places. I would not go the Cat-5 route.
shokunin is offline
post #8 of 10 Old 08-15-2003, 01:16 PM
radubinsky's Avatar
sending video/audio balanced over cat5 is usually for long runs (several hundred feed or more). +-50' is not a very long run. just make sure the cable has adequate shielding. if need be, you can always add a video amp at the equipment location later.
radubinsky is offline
post #9 of 10 Old 08-16-2003, 01:13 AM - Thread Starter
MentatYP's Avatar
Thanks for all the info!
What about the longest run of regular composite cable? I have to run VGA and composite in parallel, because we'll be using some computer output and some plain RCA composite output from devices like VCRs.
MentatYP is offline
post #10 of 10 Old 08-16-2003, 09:55 PM
mysphyt's Avatar
There are details on making your own CAT5 video cables here.
My experience has been shielded CAT5 works great for up to 50', unshielded up 30-40', longer at lower resolutions.
It's tough to beat 5 quality RG-6 cables (like Belden 1694A or Canare) for RGBHV connections or three for component.
mysphyt is offline
Closed Thread Tweaks and Do-It-Yourself
