Monster Power HTS5100 MKII-Help setting up switched/unswitched equipment - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-07-2017, 08:23 PM - Thread Starter
todd1010's Avatar
Quoted: 25 Post(s)
I have a Monster Power HTS5100 MKII power center for connecting all of my equipment to and for some reason I cannot get anything connected to a SWITCHED outlet to turn on.
I have my remote turn on wire running from my AV receiver to the DC in on the back of the Monster unit. The AV receiver is plugged into a UNSWITCHED outlet as the manual says to.
I have or want my mono block amps to be on a SWITCHED outlet and a light/lamp that is plugged into the power center to turn on when everything else turns on and them turn off when everything turns off.
Ideas?
It could be a user error I'm overlooking but not sure anymore. LOL
todd1010 is offline
post #2 of 5 Old 07-07-2017, 08:25 PM - Thread Starter
todd1010's Avatar
Quoted: 25 Post(s)
Oh, and before you guys beat me up over having a Monster Power center. I didn't buy it to make my audio equipment sound better. I like the way everything plug into one unit and makes for wire organization a dream.
todd1010 is offline
post #3 of 5 Old 07-10-2017, 01:26 PM
jautor's Avatar
Quoted: 1329 Post(s)
Liked: 852
Are you sure your AV receiver is providing a 12/24V trigger? You can check that with a voltmeter. The triggers almost always need some menu setup (although they usually default to simple on/off).
What model AVR do you have, that can make things easier to debug...
Have you set the remote on/off button on the front? You plug your trigger cable into the "DC input" not "DC output"?
You can also test the trigger functions using AC - plug a cord from the "AC input" trigger to a wall socket (should make everything turn on).
Jeff
NOTE: If you find dead photo links in any of my posts, please PM me and I will fix it.
jautor is online now
post #4 of 5 Old 07-10-2017, 04:25 PM - Thread Starter
todd1010's Avatar
Quoted: 25 Post(s)
I think I know what my issue is that my Pioneer Elite SC05 needs to have the 12v trigger turned on for the 1-2 port.
I think once I do this everything will work just fine.
todd1010 is offline
post #5 of 5 Old 07-10-2017, 06:29 PM - Thread Starter
todd1010's Avatar
Quoted: 25 Post(s)
Thanks Jeff,
What was going on was I had my 12v trigger wire going to the out instead of the input.
Its always something small. LOL!
Thank you!
todd1010 is offline
Reply Tweaks and Do-It-Yourself
