turn on AVR non Ir solution - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-14-2017, 11:14 AM - Thread Starter
stopdrpnro's Avatar
Quoted: 23 Post(s)
plan consist of a pioneer sc-95 with atmos channel preouts feeding a denon avr 988. Both have 12v out triggers but neither have trigger in . denon has room to room remote in and out. i have a harmony one/900 but i would like to avoid using that since i use my xbox kinect voice commands to control everything. A trigger power strip would send power to the denon but it would be in standby. is there any non ir solution that would turn the denon on with the pioneer
stopdrpnro is offline
post #2 of 4 Old 07-17-2017, 02:33 PM
jautor's Avatar
Quoted: 1331 Post(s)
Liked: 852
Sell the Denon and use the proceeds to buy a 2-channel amp with 12V trigger... (heck, I'll sell you my extra AudioSource AMP-100 if you need one)
NOTE: If you find dead photo links in any of my posts, please PM me and I will fix it.
jautor is online now
post #3 of 4 Old 07-18-2017, 08:50 AM
smoothtlk's Avatar
Quoted: 82 Post(s)
Liked: 45
What is it you are trying to do?
You have one AVR feeding audio to a second AVR? To do what?
Not understanding the slightly larger picture of the plan.
A Master Controller can certainly turn the AVRs on (via IR, via serial, via TCP, whatever).
smoothtlk is online now
post #4 of 4 Old 07-19-2017, 11:19 AM
holl_ands's Avatar
Quoted: 574 Post(s)
Liked: 253
There are Energy Saving [aka "Green" or "Smart"] POWER STRIP/Surge Suppressors that you could use. Plug the Pioneer into the "MASTER" Socket and the Denon into one of the "SLAVE" Sockets. When you turn the Pioneer ON/OFF, the "SLAVE" would also be turned ON/OFF. The fol. choices ALSO have very effective RFI/EMI Filters....there are also less expensive choices without this feature:
Anyone else plug their subwoofers into "smart plugs"?
PS: Hopefully Denon does NOT lose any Set-up Info upon Loss of Power......
holl_ands is offline
Reply Tweaks and Do-It-Yourself
