XML-string to change output - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-21-2017, 03:21 PM - Thread Starter
Micke Hedqvist's Avatar
Liked: 0
Hi
I trying to find the real XML-code to change the output to AV2 on my rx-a1030
Pls
Micke Hedqvist is offline
post #2 of 5 Old 07-22-2017, 07:34 AM
sbarnesvta's Avatar
Quoted: 18 Post(s)
I have never seen XML strings for controlling one of these AVRs. Here are the command sets I have using to control mine. They are the same set for RS232 or IP control.
Name:	Screen Shot 2017-07-22 at 7.28.08 AM.jpg
SBTS-Inc.com
- Certified Crestron Programmer and DM T-4K, D-4K, E-4K Certifications.
- RTI Programmer/ Driver Developer
- Rational Acoustics Smaart Certified
- QSC QSYS Lvl 1 and 2 Certified Programmer
sbarnesvta is offline
post #3 of 5 Old 07-22-2017, 09:05 AM - Thread Starter
Liked: 0
Soo. How do you put that on A webpage to simple change the output like the internal webgui or home-
Assistant
I found some XML-code that you send to IIt with ex. Curl post
<YAMAHA_AV cmd="PUT"><Zone_2>
<Input>
<Input_Sel>AV 2</Input_Sel>
</Input>
</Zone_2></YAMAHA_AV>
post #4 of 5 Old 07-23-2017, 11:58 AM
sbarnesvta's Avatar
Quoted: 18 Post(s)
Assistant
<Input>
</Input>
What are you using as a TCP client to connect to the AVR? The AVR has a built in web server that allows you to make these changes via their web browser or app, but I thought this was a closed system and only authenticated to their app.
For the control system I am using (Crestron) I have to run a TCP client to connect to the AVR via an TCP/IP connection.
I have never seen a way to control on of their AVRs via XML scripts.
There is some decent info in this thread from the Vera Forums.
SBTS-Inc.com
post #5 of 5 Old 07-23-2017, 12:46 PM - Thread Starter
Liked: 0
I was trying to send it with post-addon in firefox
Some command comeback with some answear
How does home-assistant communicate with the reciver ?
Rest-api ?
There is also plugin to domoticz avaible
https://github.com/thomas-villagers/domoticz-yamaha
And some Python script called RXV
https://github.com/wuub/rxv
Reply Tweaks and Do-It-Yourself
