how long for rca cable? quality - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-23-2003, 07:54 AM - Thread Starter
chrisintx's Avatar
How long is good to build a RCA cable for video and audio before loosing video or sound quality?
chrisintx is offline
post #2 of 3 Old 09-23-2003, 06:32 PM
WD-40's Avatar
I can't answer your question, but I can say that if you use good quality coax cable, you'll have better results than a cheap wire pair cable.
- David
... when I bought my first pair of CRT projectors, nobody ever told me they worked like rabbits!
WD-40 is offline
post #3 of 3 Old 09-24-2003, 04:28 PM
philba's Avatar
I suspect you could make the pretty long will no ill effects. I have a component set and composite that are 44 ft long. I also have several runs in my home's AV dist system that are 100+ ft . no problems at all. I used RG6quad. One run from a camera is about 300 ft and that needs a booster amp.
philba is offline
Closed Thread Tweaks and Do-It-Yourself
