Omage AV21 tweaks - Page 4 - AVS Forum | Home Theater Discussions And Reviews
Closed Thread
post #91 of 100 Old 07-01-2004, 02:21 AM
dvdvideo's Avatar
Thanks for the info. I don't have set anymore but I do have a soft spot for them still. When I first had the older unmodified set I found them to be flat and dull sounding. Then I got the new ones and found them much inproved in that regard but overall much to bright/harsh in the treble, LOL.
I never did do your crossover upgrade though, I have no speaker building skills or soldering skills to speak of. Still curious though.....
dvdvideo is offline
post #92 of 100 Old 07-01-2004, 08:58 AM
AudioJosh's Avatar
Quoted: 248 Post(s)
Liked: 227
One of the tweeters in my AV21s went bad, not sure how this happened as I never played them very loud, but it clearly happened. I confirmed that indeed it is a bad tweeter because I swapped speakers, then tweeters and isolated the problem to the tweeter.
Does anyone know what tweeter this might be or where to get a replacement?
JoshK on most other audio forums
Quantity only when quality is ensured.
AudioJosh is offline
post #93 of 100 Old 07-01-2004, 03:50 PM - Thread Starter
AldebaranTech's Avatar
I have no idea where to get another tweeter, other than to ask where you purchased them. Please let us know if you find out.
AldebaranTech is offline
post #94 of 100 Old 07-03-2004, 09:49 PM
AudioJosh's Avatar
Quoted: 248 Post(s)
Liked: 227
I have a feeling they are going to be hard to track down. Look like SEAS tweeters on the outside but the back would suggest chinese knockoffs.
I bought them from master-vox.com some 3 months ago.
By the way, I implemented the zobel network even though one of the tweeter was blown just to hear it on one speaker and I think it is a clear improvement, particularly in the midrange.
post #95 of 100 Old 07-03-2004, 10:54 PM
Johnla's Avatar
Quoted: 39 Post(s)
Liked: 30
Are you saying there is no warranty at all on these speakers?
Because if there is a warranty, you should be able to get new drivers from one of those listed below.
In the US
http://www.omageusa.com/
info@omageusa.com
In Canada
http://www.davecohifi.com/
info@davecohifi.com
Johnla is offline
post #96 of 100 Old 07-03-2004, 11:18 PM
AudioJosh's Avatar
Quoted: 248 Post(s)
Liked: 227
Don't know if there is a warranty, actually didn't think of that. Thanks for the links though, I will look into it.
I definitely feel these are a great speaker for the $$. I have heard many kilobuck speakers sound weaker. I am happy with them for my bedroom system.
post #97 of 100 Old 07-29-2004, 02:09 PM
AudioJosh's Avatar
Quoted: 248 Post(s)
Liked: 227
Just to follow up, I tried to contact master-vox.com to ask them if I could order a replacement tweeter and after not hearing back for about a month I guess, I emailed the US dealer for Omage. Apparently the US rep got a call from Mastervox that same day and he gave me a call. He verified my address and then when I asked him what I owed him he said nothing, since they are under warranty. I am quite happy with this service! I guess after years of dealing with the typically mass market companies I didn't expect actually good customer service. Way to go Omage!
post #98 of 100 Old 10-20-2004, 05:26 AM
dvdvideo's Avatar
A heads up for this old thread......A new set of Omage has appeared on Master-vox.com, this time triumph series and the bookshelf at a astonishly low $90 Canadian.....almost ordered a set.....
33lbs a pair....a fairly large......weight implies build quality higher than the price for sure.
dvdvideo is offline
post #99 of 100 Old 10-21-2004, 09:21 PM - Thread Starter
I just tried to order a set, something isn't working on the website. Will order a pair by phone I guess and report back when I get them.
post #100 of 100 Old 10-24-2004, 11:52 PM
dvdvideo's Avatar
Glad to hear it! Can't wait to hear you thoughts on them.
dvdvideo is offline
Closed Thread Tweaks and Do-It-Yourself
