Digital Coaxial dyi cable.. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 11-20-2003, 04:26 AM - Thread Starter
anbjornk's Avatar
Hello folks,
I'm about to put together a SPdif cable for my Dvd player -> Reciever.
I've recently made 6 pcs. 1m(3ft) cables for analog 5.1 sound.. I used [93ohm - 15pF/ft RG62]. Is this cable also suitable for digital signals, like SPdif..??
Regards
AK
anbjornk is offline
post #2 of 8 Old 11-20-2003, 06:00 AM
Rop
Rop's Avatar
Hi AK,
Ideally you'd want 75 Ohm coax, since that's what both ends are terminated with, but 93 Ohm coax gives you a VSWR of 1.24 : 1. That's very close to ideal (anything under 1.5 : 1 is generally OK), so it'll probably work just fine.
-Rob-
Lies, damn lies, and interconnects...
Rop is offline
post #3 of 8 Old 11-20-2003, 06:23 AM - Thread Starter
anbjornk's Avatar
What's VSWR? :o
Would it be better using 75 Ohm for analog 5.1 sound too? And not 93 Ohm?
Regards
AK
anbjornk is offline
post #4 of 8 Old 11-20-2003, 06:55 AM
Bill Lummus's Avatar
No, the characteristic impedence doesn't matter for analog audio, but it does matter for digital.
I personally wouldn't use the 93ohm cable for a digital interconnect. Stick with some good 75ohm cable. I like DIY and think the 1506A will serve you VERY well in this application. You can probably buy this by the foot from various retailers.
Bill Lummus is offline
post #5 of 8 Old 11-20-2003, 07:06 AM - Thread Starter
anbjornk's Avatar
Ok, then thats what i'll do..:)
One more question..
I guess 93 Ohm coax will work fine as sub cable then..
Regards
AK
anbjornk is offline
post #6 of 8 Old 11-20-2003, 09:05 AM
yep
post #7 of 8 Old 11-20-2003, 10:53 AM
Swampfox's Avatar
Originally posted by anbjornk
What's VSWR? :o
AK
http://www.gigaant.com/antennabasics...owhow/VSWR.asp
Swampfox is offline
post #8 of 8 Old 11-20-2003, 10:59 AM - Thread Starter
anbjornk's Avatar
Thank you for helping me out here guys..:)
Regards
AK
anbjornk is offline
Closed Thread Tweaks and Do-It-Yourself
