monoprice toslink - fancy vs. regular - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-02-2006, 03:59 PM - Thread Starter
nitman's Avatar
I was looking at monoprice.com's toslink cables and saw that they had fancy connectors that look like thy are gold plated and regular plastic cables. Would the gold ones do any thing for audio quality? I don't see how it could. Also the regular cables are $2 less.
nitman is offline
post #2 of 6 Old 07-18-2006, 07:45 AM
IndieRockSteve's Avatar
they are just beefier connectors, the gold plating isn't gold, its some paint or something to give it the shinier look. I opted for the fancy connector just because it has a more solid feel in your hand and are usually easier to grab from my experience.
So it comes down are you willing to spend teh $2 for the non-audio related advantages.
Denon AVR-S700W, Energy Take 2 f/r + Center (Original's, pre-"Classic" Model)
Samsung PN60F5350AFXZA
Marantz UD5007, Tivo Roamio, Amazon FireTV Stick, Asustor AS5004T
Belkin PureAV PF-60
IndieRockSteve is offline
post #3 of 6 Old 07-19-2006, 01:03 AM
ArcCoyote's Avatar
I bought a set (component+audio, toslink, ethernet, speaker wire) from monoprice, went with the cheapest grade on everything, and was amazed to find the cables and connectors are at least the same quality as anything costing 10x from a retail store.
Especially the optical cables: the monoprice toslink has a decent thickness to the shield around the fiber optic core. My other toslink cable is much thinner, and I'm afraid I'll break the fiber every time I have to move it.
"Real Stupidiy beats Artificial Intelligence every time" - Douglas Adams
The canine couch warmers: Dakota "Derp Dog" Jones, Gadget (the gidget widget), Dixie Marie-Doodle, Ronnie James, and Carl
The feline overlords: My wife, a.k.a. "Kitten", Sweet Pea, The Poof, Fat Tony, and David "Babycat" Tennant.
ArcCoyote is offline
post #4 of 6 Old 02-11-2007, 12:43 PM
flags's Avatar
How do you install the cable with the fancy connector?
flags is offline
post #5 of 6 Old 02-19-2007, 03:21 PM
xmenxmenxmen's Avatar
Plug it into the light, I suppose?
No matter cheap or premium, etc, digital is digital as long as it gets from point a to b.
xmenxmenxmen is offline
post #6 of 6 Old 02-19-2007, 04:25 PM
flags's Avatar
flags is offline
Reply Tweaks and Do-It-Yourself
